engine mounts
Old Mar 21, 2010 | 06:16 PM
79mini1000's Avatar
79mini1000
engine mounts
just ordered in a full engine mount kit, cuz every one of my mounts is worn... anyways, wondering if theres any things i should be expecting... in a bad way, or if they are just sub them in for eachother, also if someone has pics of where each one is supposed to go, i think mine might be missing one(prev owner was an idiot)
thanks.
Old Mar 22, 2010 | 08:18 AM
miniroll's Avatar
miniroll
they are pretty much a sub in for each other, The left enigine mount, mounts to the bottom of the clutch cover, the right one is below the radiator mount. That is all the engine mounts. The engine steady bushes are another, just take off the steady, pull out the old ones and put in the new. Thats all there is to it. If you want to stiffen your front end up then replace the subframe mounts with solid ones.
Old Mar 25, 2010 | 04:42 PM
OKMini's Avatar
OKMini
Did you buy the engine mounts with the nuts built into the mount? Makes life so much easier without trying to get mounting holes, bolt and nuts all at the same time!!!! Well worth the extra few bucks for a lot less hassle. My original mounts had the nuts welded in place the first time I pulled the motor - when I rebuilt the car I installed new mounts with the captive nuts and new bolts.
Click Image for Larger View
ENGINE MOUNT W/NUTS MINI COOPER
You might be surprised to know how much these little motor mounts can impact your total car- handling, comfort and even controlling the chances of having the engine move so far as to significantly damage the carb or manifold, etc. Two required per car and the are only held in place by 5 simple bolts!
Old Mar 25, 2010 | 04:48 PM
OKMini's Avatar
OKMini
I have some pictures of my engine when I pulled it that show the mounts of you need something. I also have pics of the engine steady bars as well. PM me if you need a picture of two!
Old Mar 26, 2010 | 04:17 AM
79mini1000's Avatar
79mini1000
pics would be great, they have the nuts welded on as well, i got a bag of things...
2 dogbones(one upper, one lower, mounts to my clutch crank case on the bottom)
1 thermostat to brake res
2 mounts
i think thats it
Old Aug 7, 2011 | 07:29 PM
Gizmo's Avatar
Gizmo
Still have those pictures, OKMini?
woodstudio
Mar 15, 2020 08:28 AM
silence2-38554
Nov 12, 2015 09:39 AM
sleek55044
Aug 21, 2015 10:52 PM
Aug 19, 2015 12:51 PM
