ENGINE STEADY
Old Mar 18, 2010 | 09:06 PM
vic170's Avatar
vic170
ENGINE STEADY
what engine steady is better the one that goes from the bulkhead to the thermostat housing or the one that goes from bulkhead to the top two water pump bolts....
Old Mar 19, 2010 | 09:48 AM
miniroll's Avatar
miniroll
they both would work just fine. A little advice thou.......unless you are extremely racing your mini, then the stocks ones will work just fine to hold the motor in place. If you want something that looks a little bit nicer then the stocks ones....check out this link. They ship overseas.....look under engine steady bar
http://www.dsnclassics.co.uk/acatalo..._Parts_33.html
Old Mar 19, 2010 | 05:50 PM
vic170's Avatar
vic170
I'm running it stock.. but it looks like the engine moves to much....
Old Mar 20, 2010 | 06:37 AM
miniroll's Avatar
miniroll
It sounds like then the bushings in your engine steadys have worn out. They are cheap and easy to install.
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
