Wheel stud help
Old Mar 8, 2009 | 01:04 AM
MtyMous's Avatar
MtyMous
Wheel stud help
Hey guys. I've got 8.4" brakes up front and one of the studs is missing so I definitely need a new one. Anyone know of a place I can get 16 new studs and what sizes I need as well as lug nuts? I've got a 1989 spec mini with 13x6's all around.
Old Mar 8, 2009 | 04:47 AM
stratman977's Avatar
stratman977
If the stud broke off because the lugs weren't tightened and it was driven like that you may need a new wheel hub. The hole where the stud press fits into gets rounded out and it will never tighten.
I would replace the studs on that wheel but I don't see a real need to change all of them.
Old Mar 8, 2009 | 06:24 AM
Minimad's Avatar
Minimad
Minimania.com
Old Mar 8, 2009 | 01:32 PM
MtyMous's Avatar
MtyMous
I asked for a full set all around because I'd like to just have them on hand. I don't think the hole where the stud is pressed into is rounded out. I am pretty sure the stud snapped for some reason and was never replaced before I bought it.
Does anyone know what size I'll need for my 8.4" rotors? I think the 2 1/4" studs are the ones I need, but none of the information I have found says anything definitively.
Old Mar 8, 2009 | 02:58 PM
Red Riley's Avatar
Red Riley
Should be this one, but I would measure what's on the car and get the same ones.
From Mini Mania: This is the correct length for all minis using the rear spacered type drum as fitted to all Cooper "S", 1275GT and every mini from 1984 to 1996 except the ERA Turbo and Sportspac cars (with had 13" wheels)
Length of shaft, not counting head, 2.25". Length of threaded portion, approx. .875"
http://www.minimania.com/web/Item/21A1278/InvDetail.cfm
If you call Mini Mania, they can tell you for sure. They've got some pretty knowledgeable folks answering their customer service number.
Old Mar 8, 2009 | 03:02 PM
MtyMous's Avatar
MtyMous
Awesome. Thank you. I'm gonna give them a call tomorrow and find out for sure.
Old Mar 9, 2009 | 12:09 PM
jeffm5150's Avatar
jeffm5150
What's the stock hardware used to secure the wheels to the drive flanges; studs or bolts? My '73 uses lug bolts to secure the (12" Minilite) wheels, not studs (similar to the MINIs produced by BMW - it was like that when I bought it. I want to convert to studs to be compliant with racing tech regulations.
Just curious,
Jeff
Old Mar 9, 2009 | 12:45 PM
Red Riley's Avatar
Red Riley
Not sure what kind of hubs you have, but I assume they are threaded to accept the wheel bolts. Mini Mania sells a bolt/stud conversion kit for the BMW MINI: http://new.minimania.com/web/Item/NMW1009/InvDetail.cfm
They might have something similar for classic Minis, or you might have to change your hubs to take the stock studs. I'd call the Mini Mania help desk, they could probably tell you for sure what you need.
khumpert
Nov 30, 2015 11:48 AM
MINI VINI
Oct 13, 2015 08:57 AM
madmaxxed
Sep 2, 2015 03:32 PM
rckrzy1
Aug 26, 2015 09:12 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
