Ground problem????
Old Aug 17, 2008 | 04:57 AM
miniroll's Avatar
miniroll
Ground problem????
Having a small problem........finishing up a restoration and when cranking the engine the ground wires on the battery and the one on the top engine bone gets "smoking" hot. Any ideas on what could cause this? The starter as well gets hot within a matter of seconds
Old Aug 17, 2008 | 09:23 AM
Capt_bj's Avatar
Capt_bj
Ignition off all is OK?
Ignition on all is OK?
Ignition to start and the cables and starter heat up, and no crank?
Does the starter turn at all? Is the starter shorted?
If the ground was bad you'd have no/low current flow and that means too little juice @ the starter. If things are getting hot you have too much flow cuz of too little resistance/energy consumption....is my thought
The starter is toasted.?What happens if you jump the positive bat cable to the starter lug?
I'd be checking the connections at the starter solenoid....my guess is something is crossed there; or the solenoid is bad. But this is also based on the wiring I find in my 79....a remote mount solenoid.
What year?
Positive ground? (older might not be)
Alternator or generator? (again age based)
Remote solenoid or integral to the starter?
arf88
May 31, 2016 03:07 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
SolCalMini
Aug 29, 2015 07:25 PM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
