Speed
Old Apr 5, 2008 | 02:53 PM
jimmybruffett's Avatar
jimmybruffett
Speed
Ok I have a Mini 1000, so i am not expecting a rocket,but my question is. It seems like the engine is really working hard to go 65 70 miles an hour. Should a 998cc be able to do that speed with no problem? I am thinking maybe my timing is off or the carb needs adjusting (I did just move from ND to UT) The motor is in good shape and runs well at lower speeds but seems like it is really working to go 70. It runs best with a little bit of choke. Please any suggestions would be appreciated.
Old Apr 5, 2008 | 04:09 PM
Rocan's Avatar
Rocan
It shouldnt struggle TOO much, but the 998 will struggle a bit.
Old Apr 5, 2008 | 04:38 PM
sideache's Avatar
sideache
I have a 998 and it cruises at 70 - 75, starts to struggle at 80. You may need to adjust the carbs. Check to see if you have oil in the dash-pots.
Old Apr 5, 2008 | 05:19 PM
Minimad's Avatar
Minimad
How hard your motor works depends on your final drive ratio.
If you have a standard 3.44:1 differential then you only get around 16.4mph/1,000rpm, going with a 3.1:1 gets you up to 18.+mph/1,000rpm, and a 2.96:1 gets 19.+mph/1,000rpm.
So, with a 3.44 going 65mph you are doing 4,000RPM! To do 70mph you need to turn 4,260+RPM. Yes, that is a lot.
I find my 1098 "likes" it between 3,700-4,000RPM. More than that and you can hear the difference on the motor.
Old Apr 5, 2008 | 06:09 PM
MINIxB's Avatar
MINIxB
My 998cc makes a bunch of noise and kinda struggles at 65. But around 50-60 she does pretty good. She's an automatic, btw, if anyone was wondering.
Old Apr 5, 2008 | 11:47 PM
jimmybruffett
Ok then mine does well at 50 to 60 then after that it struggles. I guess it would not hurt to have the timing and carb adjusted. Even at 50 mph it is the most fun i have ever had in a car.
Old Apr 6, 2008 | 04:55 AM
Minimad's Avatar
Minimad
Always a good idea. If you still run points, I would suggest converting to a Pertronix ignition and coil. Set it & forget it.
Gremothra
Sep 9, 2015 08:42 PM
tylewis
Sep 6, 2015 01:07 PM
Ntety
Sep 2, 2015 08:39 PM
SneedSpeed
Sep 2, 2015 05:34 AM
