quickshifter and bushing ?'s
Old Mar 23, 2008 | 12:05 PM
jeepster's Avatar
jeepster
I am looking at the quicksifter that has the collar on it. I want to know if it angles the shifter rearward at all. I am moving my seat way back and lowering the column, and am worried about not being able to reach the shift lever. Does this help at all?
Also, does anyone have the full poly bushing conversion. I was going to do the extra engine stabilizers and switch to all poly suspension bushings. Would installing poly engine mounts with all the rest cause me a ton on interior vibrations? thanks
Old Mar 23, 2008 | 12:14 PM
Guest's Avatar
Guest
I have full powerflex engine mounts and tranny mounts along with a TSW Engine damper. and have no noticeable increase in vibrations. Not sure what you mean by a "Quick Shifter".
*Just noticed this was in the classic forum and thus my information may or may not apply to a classic.*
Old Mar 23, 2008 | 06:23 PM
Big Norm's Avatar
Big Norm
from what i know, the quick shifters are a little trick to get use to with the classic's.....i've never owned one but i have played in a mini with one......3rd is a pain to find
Old Mar 23, 2008 | 07:50 PM
joltfreak's Avatar
joltfreak
i never had a problem with mine! and i'll never go back back to a standard shifter
Old Mar 23, 2008 | 08:06 PM
travis 10 incher's Avatar
travis 10 incher
I have one.
To answer the question asked, it does not really move the shifter foreward or backwards like you describe.
Neutral is still in the middle. It just changes the throw into the gears to what seems to be shorter. Thats why its called a "quickshift".
I say move the seat back and install the column bracket and then get used to your new setup.
Good Luck.
travis
SLIDE SHOW BELOW! vtec
http://www.slide.com/r/ODBJb8vp5j_rQ...&view=original
SLIDE SHOW BELOW! 67'S
http://www.slide.com/r/xS38Mhm_4z9js...&view=original
YaTuSabe
Aug 23, 2018 11:41 AM
bahman
Feb 14, 2016 10:29 AM
pahg
Oct 5, 2015 11:50 AM
rt808
Sep 29, 2015 03:15 PM
Suspension Products
Sep 10, 2015 11:46 AM
