2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Will these wheels fit a 2024 JCW Countryman?
Old Jul 21, 2025 | 12:51 PM
JPMM's Avatar
JPMM
Will these wheels fit a 2024 JCW Countryman? If not why? and are there any that look similar that would?
Mini Countryman/BMW Wheels - Full Set 18” 225/45 r18 | eBay
Old Jul 22, 2025 | 08:03 AM
North of 60's Avatar
North of 60
The listing says 5 x 120 which is the size used on the R60 Countryman, so they won’t fit. You need 5 x 112 bolt pattern for a 2024. Some BMW and also Audi rims can be found in 5 x 112 bolt pattern, along with F60 and a few other Mini rims.
There are good websites to confirm offset, center bore and bolt pattern required.
Old Jul 25, 2025 | 06:33 AM
+1 https://www.ecstuning.com/b-genuine-...h/36109808516/
Thats it and and for the R60/R61. Also on the 2020+ F60 JCW some wheels aftermarket and OEM need small spacers to clear the front brakes. They decided to enlarge the width of the calipers and the outside can rub on the wheel. Even though the JCW calipers look the same as pre 2020.
You need 5x112.
Old Jul 28, 2025 | 08:05 PM
cargusjoh's Avatar
cargusjoh
Great info once again ECS!
Old Aug 4, 2025 | 01:44 PM
JPMM's Avatar
JPMM
You need 5x112.
so these wheels will fit a 2024 JCW Countryman?
Old Aug 4, 2025 | 01:50 PM
JPMM's Avatar
JPMM
those wheels above apparently do not fit but these are listed that do, but it seems that the photos do not represent the actual wheels in the description
2024 MINI Countryman John Cooper Works ALL4 Hatchback B48E Wheels OEM Wheels 18 inch - 36106875603 - 529 MINI JCW Thrill Spoke 18" (5x112) - Jet Black Solid - Priced Each (36-10-6-875-603) (ecstuning.com)
caelum43
Apr 4, 2025 10:59 PM
NotSoMiniCTM
Jan 22, 2022 10:23 AM
hyhenrychan
Sep 19, 2017 04:09 PM
mrk5n
112
Jul 5, 2013 05:29 PM
Hip Check
Apr 3, 2013 08:36 AM
