2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Extra Set of Tire Pressure Sensors?
Old Dec 18, 2023 | 05:26 AM
MiniDad08's Avatar
MiniDad08
MiniDad09
Greetings!
As the owner of a 2022 Mini Countryman S All4, I'm looking for an extra set of tire pressure sensors that would be compatible with my vehicle. I have an extra set of rims that I want to put winter tires on and my Mini dealer quoted me $200 per sensor. Checking on the Internet, I believe the frequency is 433 but I am not sure whether aftermarket sensors will work. Some descriptions also state that the sensors are programmable but I have no clue how to program to be compatible with an F60.
Question: Can anyone direct me to a place that I cold order 4 tire pressure monitoring sensors that could be used for my vehicle? Sincerely appreciate your input and guidance.
Old Dec 18, 2023 | 06:50 AM
Mini-Titan's Avatar
Mini-Titan
Hi! Saw your question on another forum...might as well answer it here, too! Continental sensors sold by ECS Tuning work great. No coding required. I just bought an extra one for a spare wheel. 79.00 when not on sale, if I recall correctly.
Old Dec 19, 2023 | 05:12 PM
Sinbrad's Avatar
Sinbrad
Check ebay
I bought a genuine bmw sensor for less than £30. No need to programme just relearn through car interface. Most on ebay will say if they are preprogrammed or not
Old Dec 20, 2023 | 02:54 PM
bluonyx's Avatar
bluonyx
Tirerack has them for $38 - $40 each, or you can just get them on eBay, which is what I do now. WAY WAY cheaper and I've never had any problems with them. I just use to tirerack to make sure I get the right mhz for my year and model.
Set of 4 TIRE PRESSURE SENSOR TPMS For BMW Mini 433MHz
Old Dec 20, 2023 | 06:42 PM
chrunck's Avatar
chrunck
I bought OEM ones once, but it was hard finding a tire shop to install them. The first few shops I called weren't too keen on customers bringing in their own parts.
​​​​​​Since then I've just used the cheap ones they have at Discount Tire. No issues whatsoever.
Old Dec 21, 2023 | 04:07 AM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
Here in Canada MINIs use the wheel speed sensors as part of a "flat tire monitoring system". Works fine and even my wife's luxo-boat Audi Q7 and my TTS use them. The old systems used to tell you just to check your tires to find which one was below minimum pressure, but the newer systems will tell you which corner is the culprit. Best thing is I don't have to worry anymore about sourcing and reprogramming TPMS when I buy winter tires.
kattanah
24
May 8, 2017 06:14 PM
ericraymond
20
Oct 24, 2014 02:15 PM
52804x4
Apr 29, 2013 09:03 PM
miniinhd
Feb 21, 2011 01:30 PM
