2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Bimmer Coding the F60
Old Dec 20, 2020 | 04:05 AM
  #101
ChrisALL4's Avatar
ChrisALL4
Originally Posted by Miniminic
it’s not 3 but 6 changes. 3 in instrument panel and 3 in headunit. Same lines. Then it works when you activate it in your menu through idrive.
thanks.... but when in Expert mode, I perform a search for HUD and only the 3 lines appear. I cannot seem to find the other 3.
Old Dec 20, 2020 | 04:16 AM
  #102
Miniminic's Avatar
Miniminic
3 are in a different module. 3 in instrument cluster 3 in headunit.
Old Dec 20, 2020 | 06:50 AM
  #103
ChrisALL4's Avatar
ChrisALL4
i understand that, but shouldn’t it not appear when i search HUD in expert mode?
Old Dec 20, 2020 | 08:39 AM
  #104
Miniminic's Avatar
Miniminic
again, you have to switch from module. You cannot search and get all 6 in headunit. You have to go back exit after coding these 3 lines to modules and switch to instrument cluster and search there for the other 3 in expert mode.
Old Dec 20, 2020 | 03:06 PM
  #105
ChrisALL4's Avatar
ChrisALL4
Got it! Thanks!
I thought the search was for all modules. All set!
thanks again.
Old Dec 21, 2020 | 07:09 AM
  #106
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
Originally Posted by varma1986
I have a 2018 Mini CountryMan F60 1.5Lt Turbo Base Model. I was able to code the Tire Temp using the full version of the BimmerCode & OBD adapter.
My car came with Tyre size 225 55 17 Bridgestone Runflat and after 30000kms, I recently upgraded to 225 60 17 Nexen regular tyres which allowed my car to raise its height by 0.8 inches and the official speedometer is 3-5kms more/less that the GPS/Waze speed at which my car is travelling.
The ride is good, not as firm as before and i also have no other issues otherwise with the change in the Tyre size.
For the tyres to display Temperature & Pressure our MINI needs to have special sensors/hardware installed "Inside the tyres" itself which my car does not have.
Though the feature is enabled by coding, i do not get to see the numbers of the tyre temperature & pressures.
Apparently these sensors in the tyres tend to fail quickly and hence many MINI in recent times have been shipped without this option.It also allows for the customer to save money during customisation of the vehicle.
However my MINI has sensors mounted "on the shocks" that actually let me know if i have a flat tyre. This feature is useful.
Hope the info helps.
The device you are describing is the TPMS (Tire Pressure Monitoring System) sensor. They are *not* standard in all markets. My Canadian market F60 doesn't have them, and instead uses the ABS wheel speed sensors to provide "Flat Tire monitoring" which simply means that if there's a big difference in rotational speed of any one of the tires then likely a tire is going flat. It will not tell you specifically which one is losing pressure. Interestingly, the US market F60 *does* have TPMS. The TPMS sensors are battery powered and they communicate with the car's computer using LE (low energy) Bluetooth. The non-replaceable batteries last a very long time. I have a 2008 Audi TT which is still using the original TPMS and you're right, having TPMS means that you have to have sensors in all your wheels and you also have to reprogram the TPMS when you are doing wheel changes.
Old Jan 15, 2021 | 05:02 AM
  #107
Miniminic's Avatar
Miniminic
I want to code memory function so my setting for my seat heating is remembered. I had this on my countryman se done but can’t remember the setting. Does anybody know what i have to code for this?
Old Feb 18, 2021 | 03:45 PM
  #108
PhilGood's Avatar
PhilGood
Code the following changes using ODBLink CX on my 2019 F60:
1. Turn off "Active Sound Design"
2. Fold and unfold door mirror on lock and unlock
3. Disable window lifter interruption when opening door
4. Remember last driving mode
5. One touch tail gate closing from the door button
6. Remember seat heating setting for 24 hours
It's under "Seat Module Driver"
Old Jul 11, 2021 | 11:59 AM
  #109
ApexF60SE's Avatar
ApexF60SE
It was asked earlier, but I didn't find a reply...
Is there a location/file that describes all of the coding options for F60's? I'd like to code in the JCW HUD option.
Note I have the paid Bimmercode app, tried to look into the Head Unit ECU, but received the message that it has been changed, unable to code.
TIA.
Old Jul 31, 2021 | 07:33 PM
  #110
Mand0o's Avatar
Mand0o
I'm trying to get the JCW HUD to display on my CM.
I followed these steps in Bimmercode:
HU_NBT > EXPERT MODE > HUD_SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
Code. then:
3003 FXG_AUSSTATUNG, then HUD_SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_ENABLE.
Code.
When I go into the infotainment settings for HUD I don't see any additional options. In sports mode, all I see is the my current speed. I go into Bimmercode and I've confirmed that all of the settings above are set to AKTIV.
Did I miss something?
Never mind, everything is working!
Old Oct 13, 2021 | 09:29 PM
  #111
JayWalker's Avatar
JayWalker
Upgrade 6.5 to 8.8 Display
Hello, I was curious how you were able to upgrade your 6.5 to a 8.8 display screen. I have a 2020 mini countryman that I'd love to upgrade the screen for.
Please let me know if you have any suggestions.
Old Oct 19, 2021 | 06:56 PM
  #112
eiger003's Avatar
eiger003
Do you have details on the parts and settings you used?
I have a 2018 Countryman S All4 with power seats and many other higher end features.
I'd really like to have folding mirrors and signals in the mirrors.
Old Oct 19, 2021 | 07:00 PM
  #113
eiger003's Avatar
eiger003
I call this project>Open the Wings!.
I was able to swap my wing mirrors to Power Fold feature on my F60 Right Hand Drive.
I did not have to do any coding.
The parts that i installed had the power fold feature and were an exact match in RHD & Connector Pin/Color/Configuration.
Once your MINI F60 has the Memory Seats or MINI Excitement Package you can be sure that your machine has the cable to fold & unfold the mirror.
This project involved a lot of research & a touch of God.
https://www.youtube.com/watch?v=jWdF6Ro4I70
https://www.youtube.com/watch?v=a7mLR806Nd0
https://www.youtube.com/watch?v=2BqP5m53XoM
https://www.youtube.com/watch?v=poTMPFXYC98
Old Dec 25, 2021 | 10:33 AM
  #114
Lazboytt's Avatar
Lazboytt
Does anyone know how to stop the car from going to sleep when using the computer? Even if I just use the inap to read everything it takes time then the radio turns off which I’m guessing is sleep mode and the computer would stop trying to read the car. I didn’t try to keep it running to see if it still worked. I just touched the controls in the car so it wouldn’t sleep.
any info is appreciated
Old Jan 21, 2022 | 01:09 PM
  #115
Hudsonguy's Avatar
Hudsonguy
iDrive Update
I recently installed a new digital dash (OEM) in my 2018 Countryman All4, and it coded. Everything is working well except the "turn by turn" still appear on my "heads up display" not the new dash as they are supposed to do. I was told to go to the BMW website and update my iDrive software to a thumb drive and instal in the car. aI followed the instructions and my iDrive tells me that my current software is up to date and won't instal. Any help would be greatly appreciated to resolve this situation
Old Jun 24, 2022 | 05:43 PM
  #116
grc0456's Avatar
grc0456
Just purchased 2023 F60S ALL4
Hello,
Newbie here. We just purchased a brand new 2023 Countryman S ALL4 for my wife. It’s a beauty with in Sage Green Metallic, Chesterfield Malt leather, white roof/mirrors, 19” Turnstile wheels and Iconic trim. Although I am currently an owner of a 2013 R56S 6M in Ice Blue, I have never explored the world of coding to access any hidden features. Is there a stick or primer on steps for a non-technical person to get started? I do have a Blue Driver OBDII reader.
Old Jun 25, 2022 | 03:25 AM
  #117
Angry Yoda's Avatar
Angry Yoda
Originally Posted by grc0456
Hello,
welcome! If you search YouTube there are a couple videos that give you a sense for what to expect and how it works.
personally I stick to the basic functions and never venture into advanced settings (With my luck I will cause an expensive problem given the chance).
I did run into errors but was able to restore my previous settings. A couple times the restore failed which caused a mild heart attack. But restarting my phone and doing the things BimmerCode recommends helped.
i also keep a journal of changes made, organized by coding “categories”, so I can remember what I did in case I have to restore from a backup.
I’ve downloaded my backup files too just in case something happens to my phone.
Old Jun 25, 2022 | 04:40 AM
  #118
NBCGLX's Avatar
NBCGLX
I’ve been “coding” cars since the early 2000s and one of the smartest things I’ve done in those 20 years is keep a manual log of the changes I’ve made (both original settings and the changes I’ve made). It’s tedious, sure, but well worth it, made easier now by being able to screenshot your phone and such.
Old Jun 25, 2022 | 04:41 AM
  #119
NBCGLX's Avatar
NBCGLX
I thought that cars with the HUD display the nav info in the HUD unless the HUD is closed??
Old Jun 25, 2022 | 08:51 AM
  #120
Sailorlite's Avatar
Sailorlite
grc0456 - I have a 2023 Iconic on order and have been told I won't be getting the "Power Tailgate" option. Sorry for the interruption, but does your '23 have the power tailgate? Thanks.
Old Jun 25, 2022 | 11:15 AM
  #121
grc0456's Avatar
grc0456
No power/kick to open tail gate was available (and no push button to close) at the time we ordered due to chip supply issues. Same with heated steering wheel and alarm system. They did credit us, but still bummed not to get full features. First world problems, as they say….lol. Frankly, I don’t really care about kick to open. We had that on her prior car (CRV) and never used it. Heated wheel in NE sure would have been nice in winter, though.
Old Jun 25, 2022 | 11:16 AM
  #122
grc0456's Avatar
grc0456
Thanks!
Old Jun 25, 2022 | 11:17 AM
  #123
NBCGLX's Avatar
NBCGLX
Just took delivery of our ‘23 Untamed Countryman today and it does have the power tailgate. Another Untamed Countryman delivered on the same truck did not. It’s so hit or miss right now with certain options.
Old Nov 1, 2022 | 12:27 PM
  #124
miniRogue1's Avatar
miniRogue1
why hit or miss?
And with regard to bimmer coding...are there any common issues or problems that people run into using Bimmercode. I basically bought it just for the fullscreen carplay, but am hesitant to try it at all due to possible issues and then maybe warranty concerns.
Thank you in advance.
Old Nov 1, 2022 | 04:25 PM
  #125
NBCGLX's Avatar
NBCGLX
Originally Posted by miniRogue1
why hit or miss?
Hit or miss because, as in the example I gave, two identical cars produced at basically the same time as each other ended up with different equipment (despite being spec’d exactly the same).
BimmerCode can be relatively innocuous, but it can also screw your car up if you don’t know what you’re doing. I suggest reading the user documentation on their site, and going slow with coding changes until you really get a feel for what you’re doing. Also, I highly recommend making backups before you make changes.
