R60 Bump Steer
You'll find varying reports of this. Mine has always done this due to the runflat tires. (it annoyed me to no end)
Typically, the tires are the first place to check and usually the likely culprit. So not sure if there have been any changes recently vs the past. (don't know how long you've had it)
If not that, the next thing to look for is probably going to be a bit more expensive. If memory serves me correctly (and others will know better than I do for sure) I believe it's the front control arm bushings that will wear out to the point you'll see a lot more play there as well.
Headlands
Suspension
29
Apr 5, 2010 03:47 PM
Headlands
Mar 22, 2010 10:32 AM
