R60 Question about sunroof
Old May 19, 2020 | 11:25 AM
Benjamin Knop's Avatar
Benjamin Knop
I got a ‘16 countryman all4 stick shift today and I opened the moonroof, but the front window just slides over the back one they don’t both open. Is that normal or am I having an issue?
Old May 23, 2020 | 04:07 AM
Mac McCall-Glover's Avatar
Mac McCall-Glover
Hey Benjamin,
I believe that's normal operation, My '11 all4 is the same way. likely because there is no room for the rear glass to slide back without putting it on the outside of the roof.
Congrats on your purchase,
Mac
Old May 23, 2020 | 07:43 PM
jawilli6's Avatar
jawilli6
Yes that's correct operation. If you only briefly bump the sunroof button, to crack the glass open, both should lift up in the rear of each window, both should be cracked open. If you hold the switch to actually move the glass, not just crack it open, then the rear glass pane closes completely, and the front pane begins to slide over the rear pane. Mac called it, there is no room for slides for the rear glass.
Old May 24, 2020 | 11:52 AM
mikey_t's Avatar
mikey_t
Yep, exactly how it was designed to work.
Old Jun 12, 2020 | 12:11 PM
MReiland's Avatar
MReiland
I have a 16 also, the rear glass will pop up to Vent right when the front pops up to vent, then it will lower for the front glass to motor rearward. (If it is all working correctly)
1ZippyR53
12
Jun 6, 2016 12:14 PM
LazyT
Jun 6, 2008 11:03 AM
dominicminicoopers
25
Dec 3, 2002 08:46 AM
Gatorman
11
Nov 14, 2002 12:40 PM
