R60 Need Help! 2012 Countryman All4
Old Mar 25, 2020 | 07:59 PM
Paul Lucyk's Avatar
Paul Lucyk
I recently acquired 2012 Countryman S All4 and so far I'm loving it. The only thing that bothers me is this weird noise that seems to be coming from the transmission or transfer case area??? It sounds like a gear whine. It doesn't affect my driving, the car runs smooth actually, just that noise that bothers me. It happens when I'm around 25%-40% on the gas pedal. The noise will last for about 4 seconds then it'll come back after 2 secs or so. Coasting on the freeway, the car is silent, until I step on it. I'm thinking maybe a low tranny/transfer case fluid? What do you think? Here's the video of it:
Old Mar 26, 2020 | 06:23 AM
AWD_Rally's Avatar
AWD_Rally
Moderator
Veteran: Marine Corp
I had something similar once, I thought it was going to be bad.
It actually ended up being a loose bolt that secures small cross brace that sits right behind the engine, the exhaust goes over it. I'd check to see if any of those bolts are loose and go from there.
Old Mar 31, 2020 | 05:09 AM
iwashmycar's Avatar
iwashmycar
woah, that is strange.
Also check the CVs. I know the front ones seem more up front, but any problems seem to really feel like trans or transfer given their location
Old Apr 10, 2020 | 06:48 PM
Paul Lucyk's Avatar
Paul Lucyk
I Have 0 issues with corners and the steering is tight. Under load it makes that weird sound. Everything seems to be in good working order except when under load. Its getting a bit worse now, when my gears down it shifts hard. No Check engine lights or anything in the system . I purchased a new transfer case but with no real diagnosis.
Old Apr 10, 2020 | 06:49 PM
Paul Lucyk's Avatar
Paul Lucyk
Do you have any pictures of the location?
Profile36
Nov 19, 2014 06:17 AM
Karrock
Dec 19, 2011 08:10 AM
MagothyMini
Sep 25, 2011 03:55 PM
AquaMini
Aug 27, 2011 06:42 PM
Jim&Tammy
Aug 19, 2011 12:02 PM
