R60 R60 Clutch
Old Feb 27, 2020 | 07:10 AM
Stephika515's Avatar
Stephika515
R60 Clutch
Hey everyone. I’ve got 28k on the clock. Clutch is starting to slip and chatter. Recommendations on replacement kit? Should I also replace the flywheel while I’m in there?
2016 R60 S FWD
Please and thanks in advance!!
Steph
Old Mar 1, 2020 | 06:21 PM
N41EF's Avatar
N41EF
Never did a Mini, but ECS sells clutch kits and I've used them for VW cars. Yours seems early to need a clutch. You might get away with just replacing the friction disk, but it you are going to take it apart, and plan on keeping the car a while, I'd do an aftermarket kits. Most kits are disk and pressure plate. The flywheel should last several clutches. If your flywheel is scored, you can pull it and have it machined.
https://www.ecstuning.com/Mini-2014-...etrain/Clutch/
Old Mar 2, 2020 | 07:11 AM
We got you covered. When you do the clutch sometimes the guide tube and the seal can be done.
https://www.ecstuning.com/Mini-2016-...etrain/Clutch/
Go with a stage one if you are just daily, the oem clutch and flywheel are $$$, if you like the oem feel you can get an aftermarket clutch and/flywheel which are right next to the genuine MINI parts.
Old Mar 2, 2020 | 08:08 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
R60s seem to be harder on the clutches since they are heavier and the poor throttle response built into the ECU.
I would actually recommend going back with an Original MINI brand clutch, NOT an OEM or aftermarket as they just don't work or last as long as real MINI parts.
And I would ALWAYS do the fork kit at the same time and that is why we include it with our Original MINI kits
https://www.waymotorworks.com/oem-cl...ntryman-s.html
Also while doing the job go ahead and upgrade the front control arm bushings
https://www.waymotorworks.com/powerf...s-r60-r61.html
jbluesky
Aug 31, 2019 06:41 AM
stickboybike
R60/R61 Stock Problems/Issues
Apr 24, 2018 09:40 AM
minpoe
Feb 28, 2017 12:20 PM
jwmolmen
May 12, 2016 12:07 PM
princeofwaldo
Sep 11, 2012 12:26 PM
