R60 positive camber on rear wheels?
Old Feb 11, 2019 | 07:56 PM
limey222's Avatar
limey222
Hi All, I just purchased a 2012 Mini Cooper S Countryman ALL4 this weekend. It has 56,000 miles on it and a clean Carfax report. Report records show that the clutch was replaced at 50,000 miles and the car was well maintained. I need to ask a question, while at brunch yesterday a friend was looking the car over and remarked that from the rear the wheels looked like they had a lot of negative camber on them (rear tires are closer together at the top than the bottom). Is this normal? I know that the records say that a 4 wheel alignment has been done at least twice in the past.
Old Feb 12, 2019 | 02:32 AM
cmt52663's Avatar
cmt52663
Normal - 2 degrees of negative camber is the OEM spec.
Cheers,
Charlie
Old Feb 12, 2019 | 07:30 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes it is normal for MINIs to have a lot of rear neg camber. We always install adj rear control arms and realign the car with less and dial in the rear toe to improve tire life
https://www.waymotorworks.com/h-spor...ber-links.html
Old Feb 13, 2019 | 03:04 PM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
I noticed the apparent high camber of the rear wheels when I bought my Countryman, too! BTW, a BMW tech friend of mine said that there are other alignment items such toe which should worry you a lot more than camber if you're concerned about wear!
tberardi
Mar 24, 2011 09:28 PM
chamade
May 11, 2010 03:37 PM
landev
Apr 24, 2009 06:33 PM
kartking
Suspension
Mar 8, 2009 07:42 AM
fishey72
May 4, 2008 07:39 AM
