R60 Megan Coilover LCA
Old Feb 25, 2017 | 02:01 PM
97nicolaus's Avatar
97nicolaus
Megan Coilover LCA
Greetings!
I have a question for R60 owners lowered with Megan Coilovers installed, since I am not mechanically inclined at all. Should I buy adjustable control arm? What else would I need?
Thank you!
Old Feb 26, 2017 | 11:56 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We always recommend installing adjustable rear lower control arms to get the camber and toe correct as you gain both as you lower so you will wear tires more without dialing in the alignment.
Old Feb 26, 2017 | 05:34 PM
97nicolaus's Avatar
97nicolaus
Now I'm interested in purchasing a set of rear adjustable lower control arm, because now, even before an alignment, with bare eyes, I can tell that my rear wheels are negatively cambered by a lot. Do you sell them? And how much do they cost?
Old Feb 27, 2017 | 05:06 AM
ProjectMini's Avatar
ProjectMini
Cool Megan Coil overs and....
Im sure it out there but since we bring it up.
Whats the Best Lowering Set up. Example Everything you need control arms coil overs etc. All the bells all the whistles. spacer etc.
WHATS THE MIN. Example Just coil overs / Just springs . The cheaper route.
Like i said I'm sure it been discussed but whats the Pro set up and whats the Novice set up.
Please advise hopefully from somebody with a pro set up. Any bagged MINI's out there? That s a whole other route.
Anyhow Motor on Ya bad MINI Motor Scooters
PM:wink :
