R60 Door Armrest Rattle
Door Armrest Rattle
I have a rattle (actually, more like a vibration noise) in the passenger door armrest of my 2011 (photo below).
The pad doesn't seem to be loose, but when I press on it, the noise stops.
Is this easy to disassemble? Is it something I can remove, clean, and tighten? Any suggestions for attacking this problem?
Thanks!
Thanks!
Looks like its a molded into the door piece.
http://www.realoem.com/bmw/enUS/show...diagId=51_8237
Otherwise you could see if a clip is loose on the back of the door card.
#8 or #4 or make sure #7 screw is tight.
Thanks for the responses.
I noticed that the driver side does it too, if I don't have my arm on it (which I normally do), so it seems to be a design problem.
I also thought about the fact that I never noticed this noise with the run-flat tires on, I think because there was so much other noise in the car. Now that the ride is much smoother and quieter with the Non-RFs, little things like this stick out more.
I guess I just have to turn the music up more.
I did find this thread on NAM here about the rattle and a possible solution. See if it may be useful to you.
888.280.7799 | 6am - 5pm PST
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
67morris
Dec 1, 2015 12:53 PM
