R60 Mini Countryman S rattle issue help
Old Mar 1, 2015 | 04:57 PM
Samuel_zr1's Avatar
Samuel_zr1
Hey guys so I have a 2014 mini country man s and i was hearing small vibrations and little rattle noisies at usually around 2-3k rpm. I recently removed my resonator and now it seems to be a bit worse it sounds like it's inside the cabin. Anyone know what this is or how to fix it? It's not a huge deal but definitely noticeable
Old Mar 3, 2015 | 07:35 AM
TEXMIAMI's Avatar
TEXMIAMI
LOL i was going crazy with something like this.. Check the seatbelts.. They usually will hit the plastic with there plastic.. Make sure that the back ones are not touching the side plastic panel. Put them behind the rear seats and you should be fine as well as make sure the front seatbelt faces down .. try that and let me know
Old Mar 3, 2015 | 07:47 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
The seatbelt metal clip as mentioned above can be annoying. It needs to be up close to the top where it doesn't move around, otherwise you can get some rattling, buzzing sounds. If that doesn't do it, get someone to drive the car while you be the navigator and start putting hands on all plastic panels and parts till you locate it. Which unfortunately nowadays is most of the car, plastics!
TREX
Nov 2, 2019 07:31 PM
MiniJess
Detailing 101
30
Aug 4, 2016 03:43 PM
dyeLucky
Sep 11, 2015 10:41 AM
dyeLucky
Aug 7, 2015 07:10 AM
