R60 Is the 2014 Countryman S Automatic Transmission "Sealed"?
Old May 10, 2014 | 06:19 PM
boognish's Avatar
boognish
Took delivery of a 2014 Mini Countryman S Automatic a few weeks ago, and I noticed there is no dipstick for the transmission... at least I can't see one.
Does that mean it is "sealed" like the previous mini automatic transmissions? Hope not... I think transmission fluid needs to be changed... every other car I've owned with an automatic required a transmission fluid flush and fill at least every 40,000 miles or so.
Old May 11, 2014 | 09:18 AM
bmwr606's Avatar
bmwr606
it is not "sealed", but mini says the fluid is lifetime, lifetime of the warranty i suspect they mean
checking the fluid is not straight forward on the assin xmission
there is a tube that screws into the drain hole that acts as the level set, it is already in there, the drain plug "follows" it in, it has to be removed to drain the fluid
the fluid has to be at the correct temp and the trans has to have been moved through all the different positions (forward, rev, N) prior to checking
there are threads here with detailed info
my all4 is manual, but my sisters all4 is an auto .... we will be changing the fluid every 3 years or 30,000 miles, whichever comes first!
lalroma
20
Apr 2, 2022 06:19 PM
khumpert
Nov 30, 2015 11:48 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
