R60 Automatic Climate Control
Old Jul 7, 2012 | 11:52 AM
  #26
Royson G's Avatar
Royson G
Originally Posted by starman
It just seems to me if it is still automatically attempting to reach the dialed in temperature, why decide to shut that auto light off, if I simply want a lower fan speed?
I explained why above. I'd suggest a strongly worded memo to some guy in Germany. In addition to the "auto" light, perhaps they can add a "somewhat auto" light as well.
BTW, this is how every ACC system on the market today works.
Old Jul 7, 2012 | 12:09 PM
  #27
starman's Avatar
starman
I'm sure there are some systems on the market that when the auto light goes out the ACC is no longer functioning. As for it being in the manual - it's far from clear since one section suggests that lowering it more than once shuts the system off.
Old Jul 8, 2012 | 05:32 AM
  #28
shark715's Avatar
shark715
On my 2001 Pathfinder Auto merely means that the AC compressor is on, versus Econ if it's not. Even if you manually select the fan speed, Auto remained displayed unless Econ is pressed.
Old Jul 8, 2012 | 07:23 AM
  #29
y8s's Avatar
y8s
Originally Posted by chrunck
Tip for those with auto climate control--you can change the zone and though it won't say "Auto" on the dial, it will still automatically adjust fan speed based on the temp you set it to. So if you're like me and like cold air blowing on your feet as well as your hands in the summer, you can do that.
I just tried this yesterday and the fan speed doesn't change. I wanted feet and middle vents and set the temp to a nice low temp and the fan just stayed where it was.
the upside though is that the MINI has no trouble keeping things cool inside the car and cooling the whole thing off VERY fast with the Auto AC even in 105 degree heat out here in the DC Metro.
Old Jul 8, 2012 | 08:15 AM
  #30
chrunck's Avatar
chrunck
Well that's weird. Mine will increase the fan speed if I lower the temperature. My wife's Clubman does too.
My usual order of operations (though 2 and 3 can be switched):
1. Hit Auto
2. Adjust temp
3. Hit the hand and feet vent buttons
4. Enjoy
Old Jul 8, 2012 | 03:32 PM
  #31
Nuth's Avatar
Nuth
too bad about not being able to retrofit the acc... oh well.. at least the manual is kicking out cold air
Old Jul 8, 2012 | 06:17 PM
  #32
KLOIN's Avatar
KLOIN
With the larger inside volume and double moon roof the Countryman requires more air movement or turnover in HVAC jargon. To get it to keep up in the >100F temps we've been having you have to turn the fan control up manually and the temp one setting lower than normal..Or just leave it on MAX...Once the temp drops below 95F you can go back to the auto system and it should control jut fine...My vent outlet air temp is fine...
Old Jul 9, 2012 | 12:27 PM
  #33
RobertJ's Avatar
RobertJ
In my opinion if you don't have it you're not missing much. I don't use mine at all and have lived in two very different climants since getting my Clubman. (San Antonio and San Francisco) For me the fan speed is always too low, because I like a little more air movement regardless of the temperature. It's a personal preference, and I'm sure people that like their systems are happy with it. But I prefer the manual control.
Old Jul 10, 2012 | 07:47 AM
  #34
y8s's Avatar
y8s
1. Hit Auto
2. Adjust temp
4. Enjoy
I checked it again and this time the fan did indeed change speeds. I wonder if I hit something differently the first time.
or maybe it decided to remain at a constant speed
patsum
26
May 29, 2021 06:29 PM
molala
Oct 2, 2015 01:53 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
Ntety
Sep 2, 2015 08:39 PM
