Brakes
Old Sep 30, 2006 | 08:09 AM
wamb3794's Avatar
wamb3794
Brakes
Have a 2002 Mini S with 35,000 miles. (Out of warranty and 400 miles away from nearest dealer). The right rear brake is dragging. Lots of road noise. Have the tire off and doesn't seem to be releasing after applying brake. Left wheel spins freely when jacked up but not this one. Any ideas???
Old Sep 30, 2006 | 10:22 AM
cooper99's Avatar
cooper99
How bad is the right rear brake dragging? Can you feel deceleration when you let off the throttle? And the road noise you have, are you referring to squealing brakes or something else?
Old Sep 30, 2006 | 11:06 AM
davavd's Avatar
davavd
Many years ago, I had a similar problem, not just with one wheel, though. Turned out to be crud in the brake line that would go toward the wheel, but not back, and kept the brake fluid from doing the same. Don't know if this helps......
Old Sep 30, 2006 | 06:15 PM
wamb3794's Avatar
wamb3794
No squealing. Just the sound when something is holding back, rubbing. We had the tire off last night and looked. Just looks like the pads aren't releasing after stepping on the brake.
Old Sep 30, 2006 | 11:14 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
maybe take it to Midas?
Old Oct 1, 2006 | 06:11 AM
LEPRACHAUN's Avatar
LEPRACHAUN
A collapsing brake line could probably do this. Would be a good idea to take it somewere for service. A new brake line would require bleeding the brakes, a bound piston in the caliper could require rebuild/replacement . All in all unless you feel comfortable getting into it a good mechanic is the way to go.
Old Oct 20, 2006 | 10:21 PM
wamb3794's Avatar
wamb3794
Got it fixed! It was a wheel bearing. We have changed tires, checked brakes, nothing worked. But it was a wheel bearing. It is ready to motor again. Pretty great. No more road noise!!! Thanks for input. So if you have some real bad road noise check the wheel bearings!!
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
