Service engine soon light
Old Feb 20, 2006 | 10:20 AM
Krookid I's Avatar
Krookid I
hello miniacs. my service engine soon light came on the other day so i took it to autozone for the free OBD reading. It gave me the code 02506 (or something like that) - "emissions control or minor leak." I'm not sure whether i should replace the O2 sensor. it also has not been idoling very well lately, it actually stalled out on me the other day when i slowed down. anyone have any suggestions?
Old Feb 20, 2006 | 09:32 PM
COR BLMY's Avatar
COR BLMY
You have TWO O2 sensors one before the CAT and, one after.
I really think that the sensors are working fine ... they have detected the leak.
Sounds more like a gasket or vac hose.
Emissions are covered wnder warantee longer than the regular warantee.
What year / how many moles ?
Old Feb 21, 2006 | 06:44 AM
FLORA BLUE's Avatar
FLORA BLUE
Okay, I remember a problem like this that I read about on another thread....try this first before you put all your hard earned money into it: I can't find the thread but it was someone who did not tighten down their gas cap after they filled up...the sensor registered a problem. Their mechanic told them to go put more gas into their vehicle and make sure the cap is properly tightened. Once they did that, the light went off, it was a "false alarm." Hope this solves the problem.... Mick
Old Feb 21, 2006 | 10:11 AM
Krookid I's Avatar
Krookid I
my warranty is up, 60K miles on an '02 cooper...I already tried the gas cap thing. "sounds more like a gasket or vac hose" Sounds like a good thought, would that require me to check out every vac hose under the hood?
Old Feb 21, 2006 | 04:22 PM
COR BLMY's Avatar
COR BLMY
An easy check for vac leak be it a gasket or hose is the O'L CARB CLEANER TRICK.
Put on one of those small hoses onto a can of carb cleaner (so that you can direct the spray)
With the engine running ... Spray short little bursts at the hose / area that you want to check.
If there is a leak the engine will rev up.
You can test its effictivness by doing a "test subject", take off a known vac hose and spray. The engine WILL rev higher.
... GOOD LUCK
Old Feb 22, 2006 | 12:51 PM
goldcountrymini's Avatar
goldcountrymini
My SES light just came on again... I had it reset about 2 months ago. I have not filled up in like a week so it's not the gas cap. The last time I had it reset, the dealer said it was a software glitch that caused it to go off. I will post my results as I have an appt to bring in my MINI tomorrow for service and check it out. Any ideas?
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
oldkid6
Aug 11, 2015 08:13 PM
