2012 r56 crank no start
Old Jul 15, 2024 | 06:13 PM
dinoracer's Avatar
dinoracer
Hello All,
I have a 2012 R56 S automatic
late in the winter this year I put my mini and quick jacks to do some mods. coil overs, sway bars, and a fuel filter. 3 weeks ago I finally got around to finishing the car. I know it took forever I work crazy hours.
so I found my battery tender fried the battery it was not in the car at the time of destruction. so I got a new AGM battery from my local stealership as they had no regular batteries.
the car will crank but not start. I replaced the spark plugs, the relay in the engine compartment against the firewall, and the relay on the JBE. sent the JBE to detroittuned and was just informed that the JBE is fine.
Also, the only code I get is for the cas system which the techs at Mini say to ignore. Also, it will run on starting fluid but barely. Any Help would be GREAT.
Old Jul 18, 2024 | 04:27 PM
valthun's Avatar
valthun
So, with starting fluid the car starts and runs? But then struggles to when that happens? If that is the case the mods you did has one to with the fuel system. I Would check the fuel filter installation, making sure that you didn't inadvertently create a restriction.
Minicoopersneedshelp
Jun 25, 2024 10:05 AM
NCCORGIBUS
Dec 28, 2020 04:35 PM
atraxxia
Apr 12, 2020 08:10 AM
Savagetoast
R60/R61 Stock Problems/Issues
Aug 7, 2019 05:29 PM
GT350
Dec 29, 2017 07:24 AM
