Fault codes with Cel
Old Jan 2, 2020 | 05:20 PM
Its_The_Jockmo's Avatar
Its_The_Jockmo
So I have a 08 mcs with 122k, Im getting a 2783, 277F and 28AA codes. In the past 12 months I've replaced the fuel filter, fuel injectors, HPFP, all the coil packs, spark plugs and have done a carbon blasting. Ive hit a wall with these codes and have no idea where to go next. Any help would be greatly appreciated
Old Jan 2, 2020 | 05:39 PM
RockC's Avatar
RockC
There is some disagreement as to the meaning of the codes.
When I search the codes: BMW PXXXX error code; for
P2783: Torque Converter Temperature Too High; Does the transmission have enough fluid? Too much fluid? Is it of the right type of fluid? Is there a transmission cooler? Is air flow through it blocked?
P277F: P277F Misfire Cyl 2 Error. You have changed injectors, plugs, coils, etc. What about an intake air leak?
P28AA: Bypass Valve Error. This might be the key to the misfire.
You have to be sure you are using a BMW/MINI compatible OBD2 code reader that is suitable for use with your car. Error codes of the higher numbers are manufacturer specific.
Old Jan 2, 2020 | 06:24 PM
Its_The_Jockmo
I forgot to mention it is a manual transmission so no torque converter
Old Jan 3, 2020 | 10:05 AM
Yep schwaben tool will pick up those specific codes, some other code readers just do the normal P codes. That one code does not make sense if you are a manual.
Maybe check the wire harness for animals that like to chew on the wires or something was disconnected or pinched?
Old Jan 3, 2020 | 10:35 AM
Its_The_Jockmo
I cleared the codes and the only one I keep getting is the 28AA code, from the research iv done on that code its pointing to the diverter valve. I already have the DV+ installed so im thinking the solinoid itself went bad.
Old Aug 4, 2020 | 08:06 AM
Nick Banks's Avatar
Nick Banks
Did a new Diverter Valve body fix this? I am having the same issues. Thanks
david_foster
Sep 25, 2019 08:09 AM
GorillaArms
Aug 22, 2018 10:54 AM
turbo224
Nov 25, 2015 10:02 AM
naffets
Nov 10, 2007 06:22 AM
Drama_Llama
Aug 25, 2007 11:49 AM
