Gas for your Mini
Old Jan 18, 2014 | 09:13 AM
Motogordo's Avatar
Motogordo
Gas for your Mini
Jan.18,2014
Accidentally yesterday I put in 5 gallons of regular instead of premium. I always use premium but yesterday I goofed. Any problem ? The 2007 Mini cooperS 6 speed still ran great.
Old Jan 18, 2014 | 09:16 AM
AZdsrt's Avatar
AZdsrt
You should be ok. The manual says 89 octane minimum, 91 recommended.
Old Jan 18, 2014 | 09:18 AM
bavmotors's Avatar
bavmotors
Could always add octane booster if u wanted
Old Jan 18, 2014 | 09:39 AM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Motogordo
...Accidentally yesterday I put in 5 gallons of regular instead of premium. I always use premium but yesterday I goofed. Any problem ? The 2007 Mini cooperS 6 speed still ran great.
There will be NO problem assuming you used branded gas. Your car will run fine and the computer will compensate for any issues. Putting higher octane gas than the motor is designed for is really just a waste of money.
What is important is the quality of the fuel. Only Shell for Artoo but other Top Tier or national brands are good too. Stay away from unbranded tank bottoms and mixtures.
///Rich
Old Jan 18, 2014 | 10:38 AM
Pno2nr's Avatar
Pno2nr
I also will not go to the unbranded stores even if they ad a 91 octane. The best I've noticed is Mobile. Shell is good too.
I've goofed too on the regular unleaded. I do notice some pinging and lack of performance when doing the get on it phase. I don't do it much, but try to at least get on it once or twice per tank out in the country. Way fun!
Motor on!
Old Jan 18, 2014 | 10:40 AM
Pno2nr's Avatar
Pno2nr
Jan.18,2014
So go get some octane booster, or just put in 10 gal of good stuff and you should be fine.
Old Jan 18, 2014 | 10:49 AM
DneprDave's Avatar
DneprDave
It won't make any difference, the knock sensor and the engine control unit will compensate.
Besides you still have mostly premium in the tank.
Don't worry about it.
Dave
Old Jan 25, 2014 | 10:21 AM
Motogordo's Avatar
Motogordo
Dave
Jan.25, 2014
Thank you Dave for your response. The car runs just fine. When my next fillup comes I will be back to my regular 92 octane from WaWa.
Gordon
Old Jan 25, 2014 | 02:25 PM
kg4fxg's Avatar
kg4fxg
Gas Stations
When I bought the car they told me to use only Premium. And I have.
2013 S Coupe
And the dealer told us in a meeting about how to find good approved gas stations and so I did. Something about messing up the fuel injectors and such if you run cheap gas all the time.
One tank most likely will not hurt. And maybe I go overboard. But I plan on keep the car for at least 100K like all my others.
So waste of money? I don't think so and even with the 100K warranty I want the car to run its best. But I am no expert and have not tried cheap gas to see if there is a difference.
phrza81
Oct 10, 2015 11:37 PM
mrjolliff
Oct 9, 2015 05:55 AM
dchang0
Aug 10, 2015 03:37 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
