Hi from the sunshine state (orlando)
Old Dec 7, 2013 | 05:14 PM
kimnieves's Avatar
kimnieves
I am about to close a deal on a 2010 Clubman S with 23580 miles on it. The car is a hot chocolate with a premium package. The actual owner took me to the Mini Dealer and the service manager pulled the service record on the car for me using the car key. It is sad to say that I will be taking over is loan (18.4k) cause he can affort the car payments (lost his job).
Below is what has been taking care according wit the service record.
@6,419 miles inlet valve dirty/blocked, Air inlet (including grill) on bonnet poor surface finish
@6,822 miles O-ring for injector leaking
@11,291 Air inlet (including grill) on bonnet poor surface loose
@11,586 brake fluid change (full maint program)
Micro filter replacement
1st oil service- full maintenance
Standard operation MP
@14,183 Full-flow filter body leaking
coolant pump leaking
FT brake pads -maintenance plan
Aux water pump, M17 02 12
@19,297 Thermostat permanent malfunction
RR brake pads -maintenance plan
Air inlet (including grill) on bonnet poor surface finish (3 times?)
MP-low mileage annual oil service
Do I need to worry about something else. Base on this I think the guy has being honest.
Thanks for your feedback
dgamblin
Jan 2, 2021 02:57 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
eliseo1981
Nov 2, 2015 11:24 AM
Doc Pain
Oct 28, 2015 07:09 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
