New mini S, new rims
Old Oct 14, 2013 | 05:38 PM
furlong24's Avatar
furlong24
name is jake, got this car about 3 months ago and I just changed wheels and tires but ran into an issue with the center hole of the rims being to big compared to the hub, so I thought id join here and learn a few things
Attached Thumbnails New mini S, new rims-mini.jpg   New mini S, new rims-mini2.jpg
Old Oct 15, 2013 | 06:53 AM
Mini2na's Avatar
Mini2na
You'll need some hub rings that step down the wheel to 56.1mm. You'll need to check on the diameter of the hub opening in your wheels.
Tire Rack carries hub rings. Ebay lists some of the sizes, but know exactly what you need.
Old Oct 15, 2013 | 09:05 PM
furlong24's Avatar
furlong24
are the hub rings a MUST?
Old Oct 16, 2013 | 04:59 AM
b00sted09's Avatar
b00sted09
Yes they are! It is dangerous to be driving with a loose wheel hub as it wobbles when the wheel is spinning. The hub also acts as additional support for your wheel to alleviate stress from your wheel bolts. You can probably feel a slight to moderate vibration in your steering wheel when you drive your MINI especially at higher speeds. In some situations, the steering would be shaky/unsteady/wobbly if the wheel hub is really loose.
Old Oct 16, 2013 | 06:45 AM
minsanity's Avatar
minsanity
3 decades of driving w/o hubcentric rings.....Surely, it's better & safer to have em. Just be sure to always cross-tighten those bolts should you opt to run w/o the rings for now.
Old Oct 16, 2013 | 09:48 AM
Nucci's Avatar
Nucci
+1 great advice
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
nomar116
Aug 9, 2015 09:42 AM
Aug 7, 2015 05:56 AM
