ACC mode with comfort access
Old Jun 22, 2013 | 04:50 AM
guevasd's Avatar
guevasd
We are using a 2013 Paceman at a drive in theatre. How do you leave it in ACC/accessory only mode (for the radio) with having the comfort access? I know we can just turn in the radio, but it will cut off in 30min. Is there a trick to a key fob/button press combo?
Old Jun 22, 2013 | 05:41 AM
zigziggityzoo's Avatar
zigziggityzoo
If I read the manual right, you just push the start/stop button without your foot on the brake.
Old Jun 22, 2013 | 06:46 AM
guevasd's Avatar
guevasd
That's what I thought, but with comfort access, the key fob doesn't have to be in the slot. And then every 25-30min the radio shut off. Hmmm
Old Jun 22, 2013 | 07:43 AM
chanclor's Avatar
chanclor
I watched the comfort access video here, and it says if you shut the car off after it's started, the stereo will remain on and a second press of the start/stop button will turn it off. Not sure if this still has the 30 min timeout though.
http://www.miniusa.com/AboutYourMini/
Old Jun 22, 2013 | 07:53 AM
chrunck's Avatar
chrunck
I think it always has a timeout so you don't kill your battery. When I went to the drive in a few years ago, I couldn't figure out any other option than just turning the radio back on every time it turned off.
Old Jun 22, 2013 | 11:39 AM
guevasd's Avatar
guevasd
Thanks for the input. I ended up just turning it back on. But just curious as to a 'mode' that could do jut radio, everything else off.
gar56
Nov 15, 2016 06:41 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Emnotek
Sep 29, 2015 07:37 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
krohm
Sep 28, 2015 12:16 PM
