may purchase 08 cooper S 6 MT - timing chain question
Old Oct 5, 2012 | 05:50 AM
silvermist99's Avatar
silvermist99
Hello, we're thinking about picking up a 2008 cooper S 6MT. I'm reading the timing chain thread and there seems to be a bit of problem with it. But quite a few post points timing chain fails due to low oil level. Some say 2010 + models are better, with redesigned tensioner?
Also there is a TSB for this but not a recall? If the vehicle is not under any warranty and mini don't see any timing belt issue then they won't replace the tensioner? Should it be done as a out of pocket expense to prevent future problem?
Old Oct 5, 2012 | 06:51 AM
jcauseyfd's Avatar
jcauseyfd
It is not really clear yet whether the redesigned timing chain tensioners have solved the problems. It seems to be better based the reduction in number of complaints.
The problem will typically manifest itself as a loud rattling noise, often during "cold" starts but not necessarily only in that situation. The rattling is due to the chain being stretched, the stretching causing by the tensioner not working properly.
If you don't have any rattling, you could try to replace the existing tensioner as a preventive measure.
Old Oct 5, 2012 | 06:53 AM
silvermist99
the tensioner looks like a cheap part and relatively easy to do.
why do people recommend 2010+ models over 07-09? the tensioner should the same from waht I'm reading, the longer/extended tensioner is only a bandaid fix for stretched out chains
The 2008 model I'm interested in is low mileage, have under 30k miles
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
Mini'mon
Aug 16, 2015 04:15 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
