Oil filter
Old Nov 5, 2011 | 07:34 AM
timscuba's Avatar
timscuba
Oil filter
I have a 2008 JCW and was wondering where the oil filter is. I have done a search and could not find anything. I am thinking of changing the oil my self if I can find the filter.
Old Nov 5, 2011 | 07:43 AM
selder's Avatar
selder
https://www.northamericanmotoring.co...with-pics.html
Old Nov 5, 2011 | 07:45 AM
Capt_bj's Avatar
Capt_bj
GEN2 oil filter is sort of under the coolant overflow tank
you must move the overflow tank to get to the filter - you don't have to remove it tho, just remove the one holding bolt and you can move the tank enuf w/out disconnecting the hose or draining any coolant
be careful when you drain the oil the first time - several folks have pulled the first drain they found, and drained the transmission. The oil drain is an 8mm hex, and is on the passenger side . . .
the tranny side looks like this
there is a DIY guide in the 'how to' section of the GEN2 threads but be careful, there are booboo's like saying the oil drain is a torx fitting (a torx will fit, but clearly it is a hex)
http://new.minimania.com/web/Item/G2.../InvDetail.cfm
Old Nov 5, 2011 | 08:18 AM
timscuba's Avatar
timscuba
Thanks everyone. Love the pictures. They are worth a thousand words. I now know where to look for everything.
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
Chasp
Aug 25, 2015 06:44 PM
Chasp
Aug 22, 2015 01:26 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
