HELP!!!!
Old Sep 21, 2009 | 03:50 PM
madmaxxx02's Avatar
madmaxxx02
HELP!!!!
I live in the Omaha-Council Bluffs area. I have had my Mini since 2004. I would love to keep it forvever or may be trade in for a convertible Mini....
I am new to this site... I am lost. I need to find someone else who is reliable and reasonable to help me fix my Mini. Markel is just way to expensive. I like to keep my Mini healthy, but hellooo... it's outrageous if I use Markel.
this what I need --- fluids flushed, oil casket repaired, and new tires. Can any one help?
Old Sep 21, 2009 | 04:03 PM
miniconcarne's Avatar
miniconcarne
Get some C.O.R.N. https://www.northamericanmotoring.co...aska-corn-164/
Old Sep 21, 2009 | 04:13 PM
smieska's Avatar
smieska
I live in CB and just went thru the Markel $865. oil change. It seems that the oil pan gasket was leaking which I had noticed when crawling under it a week or 2 earlier so I figured I would have to get it replaced. When the SA called me I was busy and he quoted me $600 something for the gasket which I OKed but told him I would find tires somewhere else cheaper than the $800 they wanted. Once I came to my senses I called him back about the pan gasket and he confirmed the $600 something but when he mentioned having to lift the engine to replace it I wnet with his plan. Out the door with oil change, pan gasket and $8.61 for washer fluid top off the bill was $865. I have since learned enough about the oil change thing that I have acquired the tools necessary to do it myself next time. I found tires for less than $400 at Firestone for Bridgestones that work very well. Lesson learned. If you have questions feel free to PM me.
Old Sep 21, 2009 | 06:07 PM
madmaxxx02's Avatar
madmaxxx02
Thank you for the reply. Seriously, Markel is expensive. There has to be another alternative. I did see something in Lincoln, but again I want something closer.
