Just bought my 05 MCS
Old Jul 7, 2009 | 10:45 AM
rehgee's Avatar
rehgee
i love the car but i got a few problems as it is used,
i need to get new brake pads, and was searching for a diy for it, i couldnt find it so if someone could be kind enough to help me, that would be greatly appreciated.
i need to do an oil change and just found the diy, so im good there
but the thing that just recently happened to my mini, is that the driver door is not opening from the inside, so i have to roll down my door and open from the outside which is a hassle. does anyone know how to fix that or go somewhere in socal that can fix it?
i mean i bought the car and it was in awesome condition, but within a week with letting my friends and family sit in it and check it out, i think got the driver door messed up, for someone may have yanked on the handle to hard, just to unlock it, thinking it was opening it, o well
i would greatly appreciate any help
btw my name is reggie
thanks
Old Jul 7, 2009 | 12:46 PM
DAVESTER's Avatar
DAVESTER
brakes
try this for DIY
https://www.northamericanmotoring.co...8-how-tos.html
Old Jul 7, 2009 | 12:59 PM
xsmini's Avatar
xsmini
Congrats -
As for the door not opening from the inside - the Bowen (sp?) cable came loose, or is stretched - pretty common.
You just need to remove the door panel, and re-attach the cable to the door lock actuator (located at the back of the door - just follow the cable from the handle to the actuator)
There is a how to on the door panels somewhere on this site - just do a search.
But in a nutshell its as follows:
with small screwdriver remove the reflector at top back of door (there is a torx under it)
carefully remove the ring around the door handle/ tweeter.
Remove 4 torx on the door panel. (on the 05 you may have the arm rest bolster covering it, so use a long screwdriver, or something similar to get it off, stick it between the bolster and the plastic door panel piece)
Use screwdriver to pry the front corner of the door panel up (just enough to get your fingers under) Then pull out to about 45 degrees, and lift the whole panel straight up.
Good luck
Nik
Old Jul 8, 2009 | 12:30 AM
rehgee's Avatar
rehgee
thank u so much
Old Jul 12, 2009 | 02:30 PM
rehgee's Avatar
rehgee
Thanks so did my own oil change and fixed my door but for the brakes i looked at the diy and went to autozone and got some pads but i need to buy a sensor, is te only place to get one is from mini
Old Jul 12, 2009 | 04:14 PM
howsoonisnow1985's Avatar
howsoonisnow1985
don't losose or break the little clipy things either.
Old Jul 13, 2009 | 04:59 AM
rehgee's Avatar
rehgee
ok thanks
Drumsound
Aug 25, 2015 05:22 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
PrimePower
Aug 16, 2015 06:29 PM
cjsdad
Aug 11, 2015 08:46 AM
nomar116
Aug 10, 2015 11:24 PM
