Alta Adjustable Belt Tensioner Available At Pelican Parts!
Replace your broken or worn out stock belt tensioner dampener on your Supercharged MINI! The ALTA Performance Tension Damper is a very simple device that will outlive the life of the car!
Solve Three Problems at Once
The OEM dampener is very well known to cause lots of problems on your 2002-2006 MINI. The bushings wear out causing strange noises and dampener failure. When the dampener wears out, it causes instability in your your belt tension, premature belt failure, shortened life of bushings and tensioner spring, and slippage under full throttle. Also, the OEM dampener can't protect your crank pulley and related parts from getting destroyed in the event a belt fails.
When you replace the OEM hydraulic dampener with the ALTA Performance Tension Damper, more tension is added to the belt. The ALTA Performance Tension Damper eliminates tensioner bounce and adds more tension than the OEM dampener, allowing better performance and response under extreme driving conditions.
888.280.7799 | 6am - 5pm PST
iamcamkeenan
08-10-2015 03:31 PM
08-07-2015 09:51 AM
08-07-2015 08:10 AM
