Suspension Front Sway Bar End Links
on
I have a stock front sway bar on 2008 MCS. The allen screw inside both sway bar end links is all but stripped out, and it took me some careful wrenching to disconnect them to change my suspension out. I was wondering if it would be beneficial to replace them with an aftermarket set such as the WMW ones. Or should I just order an OEM set and save my money. Any input would be appreciated. Thanks
There is a 17mm half hex on the stud of the endlinks, so there is no need to use the an Allen.
We offer a more robust endlink, as do a couple other vendors, and they will last longer than stock as well as offer adjustability to corner balance the car, or adjust swaybar angle due to lifting/lowering the car.
Endlinks
Endlinks
07-16-2020 12:54 PM
silence2-38554
11-12-2015 09:39 AM
minipopkart
08-13-2015 05:22 AM
ClayTaylorNC
08-10-2015 09:19 PM
