Feels like it's going to stall
#26
Aloha stallers?
My 04 cooper does the rough idle at stop lightstoo. I think it started after the recall for the fuel vapor emisions.
That was the only ECU work I had done since I bought the car.
The only mod I had at the time was the Alta CAI.
It ran great before.
I also have Day time runnig lights, so when I run the AC it gets worse.
I was in the shop the other day and they told me there was a software up grade for it but I have to wait till it gets here.
I think Mini of Hi uses Logs, or Bottles to get the software to Hawaii.
I am also waitng for MTH was hoping it would help, guess not.
#27
I too had this problem since the emissions recall, until the 19% and GIAC fixed it completely:smile:. IMHO it is the ECU opening the gas tank vent and creating a big vacuum leak. There has so far been no mention on these boards on whether the latest software (42.1) you speak of has fixed it or not. In fact the only post that mentions it is this one: https://www.northamericanmotoring.co...highlight=42.1
#28
Originally Posted by meanboy
Didn't read all of the responses but this is nothing new.
I've had it happen to me for months now, but i thought i'd post that it dipped then stalled, and was hoping nothing was too wrong with that
#30
on
1 Post
Originally Posted by The Short Bus
I know this isn't anything new, i had to find an old thread to revive just to UPDATE that mine actually STALLED out, rather than just kind o fdipping them bringing itself back up. Dealership didn't seem too sympathetic. It happens all the time, i know... but not actually STALLING :/
Anyway, it was warm today...over 90 degrees and the idle wasn't rough at all so I can't put my finger on when it happens. I just know it does.
#32
Heyall,
i solved the rough idle problem on our Mini S. Its an 04 with the latest software on it. The mods are Alta intake, Alta 15% pulley, mth tunign ecu flash, Alta cat back as pertanant mods prior to the fix. I put a new intercooler on a few weeks ago. It was a Forge Motorsports unit that i posted about in the Performance forum. Its been a couple of weeks now and what was a daily occurance is now a non issue. I wonder if its an aircharge temp or flow restriciton issue wiht the IC causing the problem. The car idles smooth as glass 24/7 now.
wildwestrider
12-27-2015 08:20 PM
mimaal
09-04-2015 09:09 AM
