Clutch or Slave Cylinder problem?
2005 Cooper S with 143k miles. Still on factory clutch and components from when it was rolled off the dealership lot.
- There's no leaks at/around the slave cylinder
- No loss of brake fluid from the reservoir
- No dramatic change in pedal pressure
- No grinding of gears in any direction
But the engagement point is a lot sooner than before. Almost immediately after you lift pressure off the pedal, the clutch engages. I recall the point being a bit further up the pedal stroke until recently... Maybe 3/4 of the way from where the pedal originally rests.
Can a slave cylinder be faulty without it leaking fluid from its seals? Or should I stop being in denial and start leaning towards replacing the clutch assembly? If the friction material on the clutch disc was almost worn away, wouldn't the engagement point be later through the pedal's length of travel?
Could be linkage. Also, do you know last time fluid was changed?
http://new.minimania.com/MINI_Cooper...mission_Fluids
The clutch slave cylinder is the lowest point in the hydraulic system, hence moisture and crud can collect there. Bleeding brakes doesn't do a thing for the slave cylinder. If you don't know when it was bled last, it should be done. Do diligent research before attempting this. You MUST fully depress the slave cylinder plunger and keep it depressed while bleeding.
For bleeding and replacing the slave check out our article here: http://www.pelicanparts.com/techarti...eplacement.htm. It should be useful to you. Personally, I like to use the Motive Products Power Bleeder. It's a pretty useful device and can be used on different vehicles as well. Can check it out here: http://www.pelicanparts.com/catalog/...pg5.htm#item20. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
