Cooling fan issue with Video
First off hello, this is my first post on here.
My Wife has a an '07 and the newest problem seems to be with the cooling fan. A possibly related issue is that the AC will not blow cold unless the car is moving.
In the past I've noticed that the fan will run when the car is shut off during summer months here is Florida. Yesterday when I turned off the car I heard a brand new sound! The fan was slowly turning, almost jerking (video below.) I've been looking through the forums and people seem to say that it's not too bad to replace it.
Here's my question. When I was looking for the part online I also saw listed a relay replacement. Is it possible that it's just a replay that's failing? I'm going to give it a knock with my official relay unsticker tool (a screwdriver) but is there any other way to test it? Thanks!
And if anyone has replace the whole fan, is it a pain?
Relays usually fail in an all-or-nothing way. It is very unusual for one to provide just enough current for a motor to slowly turn.
I'd check the power and ground connections first, though. Make sure that those are clean and tight. (Habit from working on older cars, but not a bad thing to check anyway.) If they are, jumper +12V to the fan power connection. If this still happens, get a new fan or fan motor. If the fan comes on full-time, start troubleshooting the relay connections.
[QUOTE=jumper +12V to the fan power connection. If this still happens, get a new fan or fan motor[/QUOTE]
Well I connected power straight to the fan and now it doesnt turn at all so getting a new fan is my next step.
Besides that, once I removed the bumper and everything else I found out that this Mini is a MK2 and looks like I never needed to remove any of that stuff. Good times!
As for your problem I think there was nothing I could add to what Slave to Felines already has stated, he nailed it!
When I first purchased my 2007 MCS 2-years ago my fan never came on even in hot summer, it was the coolant sensor in the thermostat housing and long before it started leaking. After replacement of the TH fans on a lot more often especially in warm to hot weather! All that time stopped at red lights, for 2 years all that heat soak.
Kimolaoha
07-05-2023 01:04 PM
