DSC Light is on but Tyre pressure Indicator Works
If the dealer couldn't connect to the ABS module, then the module is probably dead and needs to be repaired or replaced.
The part is ridiculously expensive. You can try an independent shop that might install a used module or can send the module out for repair to a place like bba-reman.com
07-16-2020 12:54 PM
