Aligning head lamp assy to hood
Ok when I first got my MINI the head lights were way out of alignment and not knowing MINI's I thought the large nut assy with screws in the middle were how you aligned, well now that I know that is for aligning the whole assy to the hood opening and OCD setting in I'm going nuts trying to get them perfect.
You know look at, pop the hood loosen the 3 big nuts and bolt with large washer and move then repeat 50 times last night in my 100+ degree garage and it's still not perfect. I got them close and aligned the 2 screws to get beams right but is there some magic trick to get them dead on ?
on
...You know look at, pop the hood loosen the 3 big nuts and bolt with large washer and move then repeat 50 times last night in my 100+ degree garage and it's still not perfect. I got them close and aligned the 2 screws to get beams right but is there some magic trick to get them dead on ?
Nine Plan Failed
R60 :: Countryman Talk (2010-2015)
10-14-2015 11:50 PM
09-02-2015 09:05 AM
