Low Speed Fan Resistor - we need solution
#401
I think I got what I wanted for now. I took out the fan, cut the 2 red wires that go into the resistor, bridged them together thus removing the resistor all togehter, now when I turn on the A/C the high fan turns on but only in 5 second bursts,
What controls the fan and makes it turn on in burst and not just constantly run?
#402
I have read entire thread, understand entire thread, that's questionable.
I have an 06 non S, Prod Date 03/06 5SPD
What brought me here was a response from "rhcp4life" (Thank You) to a post I made on another thread about my Power Steering Fan not spinning at all even after I took it apart and cleaned it all up.
So....I checked, and my Low Speed Fan is not working, my High Speed Fan comes on about every 10 seconds for about 5 seconds and then off again, repeat... Is it safe to assume that if I do the aftermarket resistor replacement (I like the one mounted to the engine mount) that it would solve my problem of NO LOW SPEED FAN and NO PWR STEERING FAN? Is there anything I need to check first to eliminate other possibilities. My A/C is currently working fine.
#403
So, I need to test my relays first because the low speed cooling fan whether the resistor is good or not has nothing to do with the power steering cooling fan working, is that correct? I just tested my pwr steering fan and it works when jumped so......... god my mind is starting to melt........... Anyone, Bueller, Frye.......... Anyone.......
#404
build MC and according to my VIN and realoem and the dealer, mine should take the
before March 2003 fan, yet my car had the later part and wiring (I know this for sure
as I had to ship back the first fan I ordered and then get the from 3/2003 on one).
If you're within a month or so of March 2003 build, I'd check visually first
(older part - big 3 wire harness and small 2 wire harness ; newer part -
big 3 wire harness only).
#406
Well, I reinstalled the resistor, with real soldering connections this time, and made good voltage readings. Sure enough, it's ~9 volts after the resistor going down to the fan, and the fan is blowing strongly, and in bursts. I tried just bridging without the resistor to see what high fan might look like, and it blew out the 30 amp fuse for stage 1 within about 5 seconds. So I'm confident that my fan is getting the right voltage and current, and it's just a strong blower. At this point I'm declaring success and not worrying about it any more, at least until the fan decides to crap out.
#407
Can someone please help me with this resitor business.
I bought that acrol resistor everyone uses for this fix. I have the pre 03 fan, with the relay on the fan. I tried simply cutting out the old resistor and runing the 2 end of the thinner red wire to the resistor. When I took a voltage reading, it was still 13v past the resistor. I tried testing the resisotr and it seems to be working, im getting .33 ohms on it. What am I doing wrong? also when the resistor was wired up I wasnt getting low speed stilnow i had a 12 battery hooked up the + to one side of the resistor, then checked the voltage past the resistor and im still geting 12V
#408
#409
Wire the resistor across a high current 12v supply, it should get too hot to touch within seconds, but don't leave it connected too long else it may burn out.
Also check you are measuring all voltages relative to battery -ive on the cars body.
Hope this helps.
Cheers
Chris
Hope this helps.
Cheers
Chris
#410
Ok I am totally stumped, I hope someone can help me figure this out. This is what happened.
I tested the resistor by unplugging the large plug for the fan and runing power and ground directly to the plug. ground to the brown wire and power to the thinner red wire. Mean while the resistor was wired inplace of the old one. put the power to the battery, fan runs at low speed, checked voltage past the resistor got 8.2v, keep in mind the car was not running when I did this so that is why its a little low. Then I took out the resistor bridged the wires instead, did the same thing, ran power to the plug, and now it was obvious the fan was going faster. So the resistor works, the fan works. Now when I put the resistor back in the system just as before, and turn on the a/c the fan wont run on high speed, the car eventually heats up and it starts going on and off in bursts. Here is where it is wierd. So when the fan goes on in a burst, I check voltage before and after the resistor and its 13.4v, how is this happening? There is only power in that wire ( the thinner red wire) when the fan is actaully running. Yet when I go to test voltage just as before, there is no drop? What the heck is going on?The 30amp fuse isnt blown, is it possible that the relay is bad or something? Because basically what i gather is that the system is not calling for power to go through that thinner red wire, if there was power going to that wire then through the resistor and to the fan. The resistor is wired exactly where the old one was, and like i said if you bypass the wiring system and just run power directly to the plug it functions, but when the car is on and running something isnt working properly.
Can someone explain to me in dummy terms how the older type fan system is wired? I looked at the wiring diagrams but I dont know how to read them. What am I over looking?
#411
I GOT IT!
So after looking at the wiring diagram for like half an hour, I checked the 30amp fuse for the low speed fan, Sure enough it was BLOWN. Such an idiot, when I tried to bypass the resistor the first time and bridge that connection i forgot that the fan would now be drawing 50amp not 30 amp, that is why it blew and that is why I was not getting the fan to turn on at low speed with or without the resistor. I dont have a resistor handy but Im pretty sure once I replace it I should be getting my low speed fan!
#413
Last night I installed the Arcol resistor that I picked up from Mouser. http://www.mouser.com/ProductDetail/...XjsYM7uQ%3d%3d Everything went smoothly. Drilled and tapped the motor mount for the resistor to bolt to. I used ArticSilver© thermal paste between the resistor and the motor mount which is excellent stuff. After I wired everything in, I now have low speed fan operation .
#414
cheers
Chris
#415
Eric
#417
Ok, I have read the whole thread. Thanks Chris for your solution!
Now, I am not sure if my low speed is working or not. It's not very warm at the moment, 25F to 32F.
I have a 02/05 car (Feb 2005) MCS.
I just replaced my power steering pump and power steering fan.
1. When does the PS Fan kick in?
I tried turning on A/C, low speed does not come on right away. A fan did come on after running for a bit and then went off. Not sure if it was low or hi as I don't think it sounded as loud as some people mentioned. And again, ambient temp is cool right now.
My A/C does blow cold.
I'm confused! I don't know if I should do the resistor trick or not.
#418
#420
That has really nothing to do with the separate fan used to cool the power steering.
#421
People have also talked about how the low speed affects the A/C. Your reply didn't even add any value, stop policing the thread.
#422
#424
I'm very glad to read this thread since I'm on my second fan, low speed failed again. Since the .33/100W is out of stock I bought two 0.68/50W. Cheaper too. Pics to follow, fan-side wiring only.
Vishay p/n RH050R6800FC02 - 0.68ohm/50W
#425
