FS:: Muteki 14.5x1.5mm Lug Nuts
Old 06-15-2016, 03:12 PM
WrenchMonkey's Avatar
WrenchMonkey
WrenchMonkey is offline
Category: Wheels & Tires
Price: $35
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60, F55, F56, Classic Mini
Item Condition: Brand New
Bought these from MiniMania by mistake, 35 dollars shipped OBO
You'll need the conversion studs that are 14x1.5mm pitch, these will most likely not fit aftermarket wheels, they are 23mm wide at the waist, or basically about the same size as the factory bolts, so if you're trying to fit aftermarket wheels and discover the factory bolts won't work then neither will these. But if you are the guy running factory wheels and want the stud kit for the convenience then this is an opportunity to save a couple bucks.
Old 07-04-2016, 11:51 AM
Saovalle's Avatar
Saovalle
Saovalle is offline
M14 x 1.25 CONVERTED TO M12 x 1.5 correct?
tomt111
SCCA Solo and ProSolo
12
05-23-2016 07:14 AM
alexinvancouver
Tires, Wheels, & Brakes
04-10-2016 10:56 AM
buddyglassjr
04-01-2016 09:22 PM
Lmill999
03-25-2016 06:11 PM
JWA
03-24-2016 06:52 AM
Quick Reply: FS:: Muteki 14.5x1.5mm Lug Nuts
