R56 2011 Mini hardtop Thermostat
My old thermostat is currently hung open. I bought a new one and went to do the replacement myself. The problem is when I got into It i took notice that there's a new sensor on top of my thermostat which the original does not have. Also the old connector at the bottom does not match up. At first I thought oh hey they ordered the wrong part for my car but every thermostat I see for my car is the exact same as the new one. I need help my car is due for inspection and it fails emission with the hanging thermostat. I don't know if there was a change that BMW had made to the thermostat after the car been produced and the past owner never took it in to have in changed or what. I'm at a loss and since it's a Sunday none of the near by dealships are open.
It looks like it still has the prongs in the original spot though. The connectors are just way wider than the new ones the one store up here says they have an adapter to change the plug but of course that's 50 more. I'm also wondering if Mini did an open recall for the change
The new top sensor
New bottom sensor in original location
The connector for original location
Goes from the jumper into two separate plugs ones screw in which I have show in another picture
The screw in plug
The new top sensor
The screw in plug
MINI has revised thermostats multiple times since your car was built. The best way to get the correct thermostat and correct sensor adapter harness is from your local MINI dealer. There have also possibly been recalls on your car changing the thermostat and hoses, this is where it gets fun to figure out the new parts. As much as people complain about the dealers they can get the right parts and fix it without you getting wrong parts due to possible recalls being done on your car.
