R56 Help.....
Help.....
i have a 2010 mini cooper s i recently did my water pump and waterpipe by myself i currently have multiple issues going on with the car now i have a check engine light on for p115d all i can come up with is maf but i did remove intake mainifold to vonfirm my waterpipe was leaking i can also here some sort of vaccuum leak but everything is connected and ive triple checked everything i also have another issue half of my electrical system is down as well and ive checked all my fuses under the hood and inside the car and they are all good the things that do not work are as followed diver and passenger windows windows do not go down my power locks do not work fog lights reverse lights turn signals high beams either my i terior lights or my dash lights do not work either i have also checked my grounds and they are all connected i have no idea what the problem can be i need to get my car running properly again before i go and trade this in because im loosing my cool with the car
According to the Bentley Manual, P115D is Mass Air Volume Flow "A" Too High. In regards to the P115d code, I found this thread on NAM here with some good plausible suggestions. I saw a few cases in threads where a loose turbo hose at the intercooler caused the code so check over everything there.
888.280.7799 | 6am - 5pm PST
hello,
Post a pic of the intake and engine and I can help you, done the coolant pipe , water pump, and thermostat housing many times. I would check all the connections and clamps also. Make sure the intake upper connection to the turbo is ok and both tube on the intake are secure, one gong to the valve cover and one going to the turbo.
Kenny Tsui
Electrical
12-16-2014 11:39 PM
Tacoman03
09-18-2011 06:55 AM
