Who still has their original clutch and AC?
#26
119,000 on Original Clutch, but slightly starting to slip. I'd say maybe another 10k and I'll have to replace it.
A/C - not sure but I think it is original. When I bought the car 2 years ago this May I had my mechanic flush and recharge the A/C after making sure there were no leaks. Made a HUGE difference and A/C has been working great up to current. I suggest if anyone has a slight problem with the A/C they perform that service I did. But obviously make sure there are no leaks.
#27
#29
#31
#33
What does the throwout sound like. When I start the car (It's hard to explain) I hear a rhythmic tapping / rumble kind of sound. I push the clutch in a it stops? Sound like throwout? It also shifts hard between gears sometimes. I'm not sure if Mini shifting is always a little stiff, but sometimes I gotta use a little arm to get to another gear. It takes a lot more arm to shift than my Hyundai Accent did let's put it that way.
#34
#35
Awww damn... I had a bad feeling. My logic was "If the clutch being pushed in stopped the sound, then it must be something that is pretty closely connected to the clutch.
:( this is bad news. Any idea how long it can do that before it craps out? I try to not let it idle with the clutch out.
#37
#39
#43
#44
A/C fail
At 75000 miles my a/c quit blowing cold air. Area shop wanted $1800 to replace the system. I read a tip regarding clutch coil failure being the likely culprit, it was, I purchased the clutch coil on ebay for $95 if my memory is correct. Install at local garage was $160. After a few drives everything worked fine again.
09-17-2015 09:27 AM
Powershift
08-16-2015 05:14 PM
