R50/53 Wing Tip Extension?
#104
Looks really good so far. Once you have the model complete, how are you planning on making the mold? Are you going to have it CNC machined? Will the part be plastic injection molded?
I can't wait for someone to design and make a larger hood scoop for the R53's......something cheaper than the M7 version.
#105
The plan is to have it Cnc machined, to then make a mould, and produce as many pieces as you like
On the other hand, about the scoop... Yesterday I took mine apart hahaha, and really the air that goes in to the engine bay. Meaning the gap is really not much larger than the oem scoop, so in the end it is limited by that gap. So what you really want is just a BIG *** scoop that end up in practically the same amount of air? Or what?
that would be the best case scenario. but i know that would also probably be quite a bit of work to figure out all the details.
#106
Ok, ok we'll do our best, but first things first... Spoiler extension, since I don't have enough money to develop to different products at the same time haha (I wish I could)
Another question... About the scoop, you only want the scoop or the panel that comes behind it too? That would increase the cost but would definitely give a kick *** look on carbon fiber!
#107
If you have a scoop with a bigger opening in the front (like the M7), it will grab more air because the opening has a larger surface area compared to the stock scoop opening. Yes, the opening at the rear of the scoop will be around the same size as the stock scoop….but because you are getting more air in the front of the scoop opening, you should be developing more pressure…..giving you more airflow out the back of the scoop and across the intercooler. From the tests I’ve seen with the M7 “extreme” scoop…..it does in fact pull in more air, and do a better job of flowing more air across the stock intercooler….making the intake air temps lower than what they would be with the stock scoop.
Here is a picture showing the M7 extreme scoop
http://carphotos.cardomain.com/ride_..._large.jpg?v=0
#108
the venturi effect is preety simple, its like normal traffic in a four lane highway, go down to two lanes with the same # of cars, those cars have to go subtaintially faster.
since we cannot increase pressure greatly, its taking a volume and putting it through a smaller area, this in effect makes the air traveling faster.
i also have the liner removed, no need for that plastic piece!
#109
And whatever you do don't make anything for the R56. None of us R56 owners have any money and are completely satisfied with M7 only being the hood scoop king. A stock R56 cooper S wing extension would sell well. The only company that makes them is NM engineering and they are 480 dollars :/
#110
i know im getting air there since air will not take a direct 90* corner in such a small area, the air flow will not be greatly reduced. if were actually create a flow path, i would bet that my assumtions are correct
at the very leaste it would be a turbulet flow, which likes to flow along the boundary layer longer than a laminar flow. and the boundary layer would be from my scoop to the diverter
i can only support this since i have not seen a difference with the plastic thing or without in IATs, i dont have logged, but it feels like recovery is much better since the black plastic doesnt hold in heat. but im sure that would also come in handy keeping some heat out on a really hot sunny day beating on the hood =)
in newhampshire, we dont have many days like that, and ussually im on the motorcycle anyways
