Navigation & Audio Antenna snapped off
Old 02-08-2016, 11:55 AM
swunder's Avatar
swunder
swunder is offline
Antenna snapped off
Car wash broke off my antenna -- but I'm not quite sure what broke/what I need.
I guess the entire base needs to be replaced? Can I do that without taking down the entire headliner?
pic --
Old 02-08-2016, 12:54 PM
TWISTER's Avatar
TWISTER
TWISTER is offline
Ebay has a few
You don't have to take the headline out just drop it a bit in the back
Old 02-08-2016, 01:56 PM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
The stock roof antenna base is HERE and the antenna shaft is HERE. You can go with a stubby or the stock unit. Be sure to check your manufacture date to confirm for the stock one. Otherwise, you might be able to find either of these in the marketplace. DIY help HERE, last post.
888.280.7799 | 6am - 5pm PST
Old 02-10-2016, 06:50 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
pic --
+1 just drop it a bit. Did you have the the Navigation version ( shark fin ) or the standard version with the long or stubby antenna ?
Standard: 65206920279 - 7/2004 models.
https://www.ecstuning.com/Search/SiteSearch/65206920279/
Then here is a stubby antenna option:
MINI newest version 83mm
We even have the older MINI design in URO version 105mm .
http://www.ecstuning.com/Search/SiteSearch/65202296772/
MINI
URO
OR
Navigation version 84506918548
https://www.ecstuning.com/Search/SiteSearch/84506918548/
No additional long or short antenna
Old 02-10-2016, 07:13 AM
swunder's Avatar
swunder
swunder is offline
Thanks for the info! I picked up a used base from Way and then the Cap only from MiniMania.
If they actually work properly I'll probably pick up another stubby antenna. Can't believe the whole base ripped off.
Old 02-10-2016, 07:42 AM
PelicanParts.com
Vendor
You have to be careful with car washes that are not touchless. I've seen side mirrors get ripped off before as well as multiple antennas. Glad you got it all fixed up.
Old 02-10-2016, 08:12 AM
ok, If the weakness of the plastic and the brushes of the car wash. Did you go though a brush system ? I only use laser when I have to, otherwise I try to do it by hand all the time.
Morganinaboat
12-14-2016 10:08 PM
egan311
03-16-2016 08:42 PM
slo_crx1
Suspension
03-04-2016 10:48 AM
mmdouglas
02-04-2016 06:36 AM
kmartin1971
02-03-2016 04:04 AM
Quick Reply: Navigation & Audio Antenna snapped off
