Navigation & Audio MINI Cooper iPhone iPod Charging Y-Cable Adaptor (for iPhone 5)
#26
#27
1- With the car battery on, plug the adapter into the iPhone.
2- If you get the "not compatible" message, unplug the adapter.
3- Immediately plug the adapter back in.
If you're like me, the warning won't reappear, and the iPhone's battery icon will show you that it's charging.
Apple has apparently included this warning on the iPhone for anything it doesn't recognize as "authorized" equipment -- just to cover their butts (and to encourage the purchase of equipment the make or endorse). The MINI Y adapter works fine despite the scary warning.
#28
It's undoubtedly because I often switch out of my music and over to another app without pausing/stopping what was playing. I do this because I like picking up where I left off when I return to my music.
So let's say my iPhone is connected to my MINI, but I'm not using it. Then I hear an alert sound. I touch the Home button and see that I have an email or a text from someone important. Instead of waiting until I reach the next rest stop 20 miles away, I touch the iPhone email to open it, touch-select the text, and choose 'Speak." But I won't hear a word.
That's because: if my sound system is on, I'm generally listening to satellite radio, meaning that's what my audio mode is set for. The only way I can hear audio coming from my iPhone (other than phone calls) is to switch the mode the IPOD. When I do, I'll immediately hear the last tune I was listening to on my iPhone. If I do choose "Speak" I'll hear both the spoken text and the music. The only way to avoid that is to switch over to my music, pause/stop it, return to my email, and choose "Speak."
This is like back in the day, when smart devices were dumb devices (I should know, I'm ancient).
#29
HDMI to Lightning?
so what if you combined one of these http://www.trait-tech.com/product/T-...dio-cable.html
With one of these http://store.apple.com/us/product/MD...apter?fnode=45
And an hdmi cable in the middle. Im no electronics expert by any means but looks as though that would work right?
By the way, here's the official MINI adapter on ebay, for a couple of days:
http://www.ebay.com/itm/BWM-MINI-COO...-/251352722487
Of course, you'll need a 30-pin to Lightning adapter, which is what I did when Apple switched cables.
#30
30 pin to lightning adapter
I have a 2012 MIni and I just upgraded to the I phone 6. I purchased the Apple adapter (30 pin to lightning) to use on my Y connector. It plays and charges my phone fine, but I lose all steering wheels functions with this. I don't understand why this is happening. I purposely purchased the Apple product because I didn't want to lose any functions. Any suggestions?
Also, it's not my Y connector cable because I tried it with my 4S and all functions work with that phone.
#31
Personally, I have steering wheel control of my iPhone6 - however, I don't use the Y adapter, instead I use the Apple Lightning to USB cord paired with an Aux audio cable. This setup works reasonably well, however sometimes when I connect I have no audio - unplugging the audio cable from the phone and plugging it back in resolves the issue. Also there are occasional issues with album art updating on the HU since about two IOS updates back.
The only potential solution I can suggest - if you have MINI Connected, make sure that you have updated the most recent version of the Connected software - odds are you don't, even if you took delivery of your MINI as late as early 2014...
#32
#35
I updated from iphone 4 to 6 and purchased the media lightening Y cable for my 2013 MCS with connected w/o nav. It was a bit spotty in that the mini connected apps on the iphone 6 would take a long time to load up but for the most part once they did the apps worked and I had steering wheel control of things. I did end up updating the software for the connected system on the car (MX-003.005.004; TX-003.005.008). I also updated the firmware for the Y cable (Google "BMW firmware update" to find how to do it. This improved things alot. The apps load much faster and they run more reliably.
08-07-2015 05:55 AM
08-05-2015 02:11 PM
