MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > How to
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
39 Replies, 900 Views
Advertisement
Thread Tools Search this Thread
  #51
Old 01-14-2009, 02:04 AM
mem1220's Avatar
mem1220 mem1220 is offline
Send a message via Yahoo to mem1220
Gallery
i bought the m7 OCC and it came with pretty detailed informative instructions. Anyone ordering aftermaket parts need to to talk to Peter(the owner) he really knows his stuff. Just a little info.
  #52
Old 03-05-2009, 10:09 AM
Nelson Costa Nelson Costa is offline
Gallery
Hello!
What is the best solution / performance for installation of the OCC, following pictures.
Solution 1:
Solution 2:
Solution 3:
Thanks,
  #53
Old 03-05-2009, 12:20 PM
DrPhilGandini's Avatar
DrPhilGandini DrPhilGandini is offline
My little dose of LITHIUM
Gallery
Garage
Solution 1 is partly solution 2 but with some wacky additions.
Solution 2 should be avoided as it links the two rocker cover outlets together (not a good idea).
Solution 3 is the preferred routing. (Whether you have the optional additional OCC opr not)
dr. phil
  #54
Old 03-05-2009, 03:22 PM
sonichris sonichris is offline
Gallery
i concur. solution 3. i have the optional occ and it has not caught one drop of oil, so i say it isn't needed at all.
chris
03 MCS | comptech header | milltek exhaust | alta 15% | wms 2% crank | MTH std file | H&R RSS Club Sport coilovers | IE adj camber plates | alta psrs | steve's adj rr ctrl arms | no front swaybar | homebrew CAI | homebrew catch can | defi d-gauge boost | aero grill | R56 front calipers and rotors | EBC yellow stuff | ATE super blue | 225/45/16 bfg kdw2 | flik ftd 16X7 ET42 |
  #55
Old 03-05-2009, 05:00 PM
johnf36's Avatar
johnf36 johnf36 is online now
Gallery
Yes on 3 here
If everything seems under control, you're just not going fast enough.
  #56
Old 03-06-2009, 07:25 AM
THE ITCH THE ITCH is offline
Gallery
Definately #3. Think about how MINI designed the system. By using #3 you are not changing the routing of the system. You are just inserting the OCC inline where most of the oil is coming from. If you use the routing from #1 or #2 you are tying the two vent systems together. Using either one of those methods and you end up getting more water than oil and the OCC fills up fairly quickly. Let the OCC get too full and what do you think happens next? Now you have an over flow of contaminates into the system and limited or no breathing for the system. These two methods have lead to failures of the crank case ventilation and serious failures. Just my two cents, the only safe way is #3 and only a single OCC is really needed.
Steve
  #57
Old 03-07-2009, 06:06 AM
stevecars60's Avatar
stevecars60 stevecars60 is offline
Gallery
1 = not really sure what that would do or why - FAIL
2 = no air supply to the crancase - FAIL
3 = WINNER
Like Steve said you only need 1
Just when you think a thread is dead.....................
2003 S, IB/ W, no HK sound, leather or power seats but everything else.
  #58
Old 08-10-2009, 05:18 PM
Storm180's Avatar
Storm180 Storm180 is offline
Gallery
Ok. At the risk of beating a dead horse...
Method three is simply putting the OCC in between the hose going from the valve cover on the left and the grey hose leading into the supercharger. Thats it? One splice and we're done?
Sorry, but the writeups actually made it sound a lot harder than it was.
Charlie Arrived 6/16/04 - MINI Cooper S - CooperFlags Silver\Black Maple Leaf. Alta Intake. Invidia Exhaust. Megan coilovers. M7 Pulley, Craven short shifter. H-Sport Rear Swaybar. M7 Strut Bar.
  #59
Old 08-10-2009, 06:22 PM
Gallery
yes
chris
  #60
Old 09-14-2009, 05:59 PM
PA-MCS's Avatar
PA-MCS PA-MCS is offline
Gallery
I just bought a m7 oil catch can and I've been researching the different routing options. As mention above, #3 is the best route (PCV to supercharger) I was shocked when I opened the OCC and found it was empty. I thought "what would stop the oil vapors and what not to be sucked back up?" Then I was reading about putting something in to catch the oil (example: stainless steel brillo pad) Then someone mentioned about possibility of ss pad pieces getting in the system.
So I planned on doing this with a little twist. I plan on putting a tube from the OCC intake and run it thru the brillo pad to the bottom. Then on top of the brillo pad make a round metal disc with holes drilled through. That way air can pass thru but nothing else.
What do you think? Am I just being too cautious??
2005 MCS Electric///Blue White Top & Bonnet Stripes/Alta V2 15% pulley/ Alta V2 CAI/Alta Air Diverter/Stratmosphere cat-back/ Detroit Tuned BV/M7 OCC/ Marshall Boost gauge/17x7.5 Rota Rb White w/ polished lip/Hankook Ventus 215/45-17/Screaming Demon coil/cabrio braces/brisk plugs/skid plate
  #61
Old 09-15-2009, 09:04 AM
Bigshot Bigshot is offline
Gallery
The amount of oil caught varies greatly between vehicles. Some have a lot of blowby and some hardly anything.
  #62
Old 11-21-2009, 12:03 AM
WJHMH's Avatar
WJHMH WJHMH is offline
Gallery
I just installed mine this afternoon, guess I should have checked this thread.
2005 MCS - Kurgan: Back from the dead...
  #63
Old 11-23-2009, 08:21 AM
Gallery
As long as you followed solution 3, you did good!
  #64
Old 04-15-2011, 11:03 AM
Tom2112's Avatar
Tom2112 Tom2112 is offline
Gallery
I realize this thread is pretty old. But the diagram for solution #3 is not showing.
Can someone re-upload a diagram for solution #3, since it seems to be the agreed-upon-best solution?
Thanks!
P.S. Is there anything wrong with the generic ebay oil catch cans? Why pay $100+ for a brand name when you can get the generic for $20?
2005 Purple Haze MINI Cooper S
Alta Classic 15% Pulley and Cold Air Intake - Mynes 550cc Injectors and 1 Step Colder NGK Plugs - Revolution Mini Works Tune - Detroit Tuned Tensioner Stop - Helix Short Throw Shifter
197 whp / 195 wtq
  #65
Old 04-15-2011, 05:24 PM
MINI33342 MINI33342 is offline
Gallery
Solution 3 is the same as 2 but instead of connecting both hoses to the can, you leave the passenger side one alone and only connect the drivers side hose as indicated in the drawing.
  #66
Old 04-20-2011, 11:08 AM
Tom2112's Avatar
Gallery
Thanks!
I am a little confused, though. I haven't removed my intercooler to look yet, but what does the stock setup look like?
The reason I ask is because most of the above implies that the grey vacuum line is connected directly to the PCV outlet on the crank case. But it is not the correct diameter to connect right up to the crank case. What all is being removed?
Lastly, is there an easy way to remove the devil horns so that they can be cleaned, or is that a major mechanical endeavor?
197 whp / 195 wtq
  #67
Old 04-20-2011, 06:27 PM
Gallery
The hose used for the OCC will connect up to the grey line easily.
The IC horns are a bit difficult to get to. I wouldn't worry about cleaning more than you can reach into as the IC gets most of the buildup.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
