Engine light on (cut engine power)
Old 08-22-2016, 10:54 AM
Jordan94's Avatar
Jordan94
Jordan94 is offline
Exclamation Engine light on (cut engine power)
My car went into limp mode on my drive home went away then showed up a few days later. When I cold start my car there is a loud whistle at idle. Also when the engine is running it sounds like an air leak in the engine bay and it proceeds to empty out after the engine turns off. I'm assuming it's a vacuum leak. Also when i put my car in sport mode the exhaust pops are much louder than normal. Any help is appreciated. (2012 countryman s)
Old 08-23-2016, 06:36 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
follow the hissing sound and see where it takes you. as you mentioned, possible vacuum leak somewhere. look for it and let us know what it was
Old 09-17-2016, 10:49 AM
dknutt's Avatar
dknutt
dknutt is offline
I had a loud hiss and whistle after checking my air filter. Turns out I hadn't put the airbox back together properly, and air was leaking. Unfortunately rockauto sent me the wrong filter, too.
Old 10-23-2016, 04:10 PM
JCdubGerm's Avatar
JCdubGerm
JCdubGerm is offline
Im 90% sure its your valve cover. Very common. Sometimes it sounds like the whistle is coming from your trans. Is your motor the n14? Definitely take a look at your intake system first. But it's most likely your valve cover
Jedc
Electrical
03-25-2016 09:38 AM
nhatch
08-06-2002 10:10 AM
Tollag
07-28-2002 03:31 AM
Juane
07-17-2002 01:43 PM
Quick Reply: Engine light on (cut engine power)
