Electrical OBD-II Shift Light
Old Mar 7, 2007 | 11:40 AM
IrishCooper's Avatar
IrishCooper
OBD-II Shift Light
Hey everyone a guy on our local board had a really cool idea for a shift light so i thought i would post it here for you guys to see.
Heres the link http://www.metroplexmini.org/forum/s...ad.php?t=18813
And heres what he said:
Frustrated with average shift lights that required direct coil contact or timing modules, I decided to create my own easy-to-install shift light based on the Raptor Performance (www.raptorperformance.com) LED shift light. The Raptor is a microprocessor design, it can read ECU, coil and tach leads.
After doing some research, I found out that there is a tach output on the OBD-II port. I purchased a few unterminated male OBD-II connectors {picture 1} online (http://www.obd2cables.com/products/) and wired it up. The whole thing worked perfectly from the beginning!
Here's the details:
OBD-II pin 1: +12V switched
OBD-II pin 4: ground
OBD-II pin 9: tach/ecu output
Just connect the right cables to the right pins, and you have a perfect connection with no wire splicing or transfer jumpers. There is one downside, and that is that the OBD-II port needs to be popped out of its housing, or the light's connector will contact your left shin as it hangs down if the OBD-II port is left in the OEM housing. My solution was to Velcro the two halves under the dash {pictures 2 & 3}.
I chose the silver body/black mount/red LED version {picture 4}(they're available in a huge number of color combinations); I felt this complimented the interior of the Mini the best. As for what RPM I have set the light to engage, that is an ongoing tuning process as I learn my car's peak and my own reaction times.
Best of all, its a lot of fun, especially at night. There goes another set of tires!
Picture 1:
http://www.metroplexmini.org/forum/...etimage&id=1134
Picture 2:
http://www.metroplexmini.org/forum/...etimage&id=1135
Picture 3:
http://www.metroplexmini.org/forum/...etimage&id=1136
Picture 4:
http://www.metroplexmini.org/forum/...etimage&id=1137
Old Mar 7, 2007 | 11:46 AM
MSFITOY's Avatar
MSFITOY
Hey Thanks but the metroplex links don't work...
Here's the details:
Picture 1:
Picture 2:
Picture 3:
Picture 4:
Old Mar 7, 2007 | 12:12 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The JCW shift light uses the same connections at the OBD-II connector. I took it upon myself to scope the signal on pin 9 and found it to be a perfect, 12 volt square wave with sufficient strength to drive most aftermarket tachs, shift lights and other engine speed-sensing gear.
The white/red stripe wire on pin 9 comes from the ECU pin 113, and is also used by the JCW air intake control box to trigger the flap opening at 4500rpm.
Wiring in a shift light at the OBD connector is a simple task, and instead of occupying the connector itself, tap into the wires attaching each respective pin as they lead into the connector. Just remove the knee bolster/parcel shelf to access the harness at this point.
Old Mar 7, 2007 | 12:48 PM
KevinBaker's Avatar
KevinBaker
Thats what I did when I fitted my shift light quite a while ago too, Greatbear. Its a very good signal, and works perfectly with my bendable, very low profile 10 LED shift light that was designed for a motorbike .
Old Mar 7, 2007 | 09:16 PM
IrishCooper
Hmm they worked when i posted it, the guy might have taken them down, they were just pictures of the finished install.
Old Mar 7, 2007 | 09:20 PM
IrishCooper
Ok i reloaded them from my computer
Attached Thumbnails OBD-II Shift Light-vbgarage.php.jpeg   OBD-II Shift Light-vbgarage-1.php.jpeg   OBD-II Shift Light-vbgarage-2.php.jpeg
Old Mar 7, 2007 | 09:21 PM
IrishCooper
And the last one
theblackfalcon
Oct 11, 2015 09:49 AM
Aug 19, 2015 12:51 PM
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
