Electrical Retrofitting the factory self dimming rearview mirror + Homelink
#126
#127
Other then some MINI dealerships in the region, some will do mods.
Here are some places.
https://www.northamericanmotoring.co...mechanics.html
#129
You are welcome.
#130
Everything is great here and I will be performing this retrofit. As I am interested in the mirror un-dimming when in reverse it sounds like I need to add this mirror to the VO in NCSExpert. Anyone have any idea what the code for this is? I seem to recollect it can be found in the VO on a vehicle that had this from factory. I have no way of knowing what it is unless I just pay for a day of the official BMW tools and do this via a standard retrofit which I just might since I need the latest module firmwares.
#133
dim when powered and the eye photo lens is triggered by light.
#134
#135
awesome, i gutted a gen 2 auto dim in stuck it in my gen1 R52.
#136
#137
The link was broken, its fixed now. let me know if you see a link to our site and it does not work. Thanks
https://www.northamericanmotoring.co...omelink-5.html
#139
I just brought home a 2016 Countryman JCW. My local dealer poached this from a box in Oxnard. Basically, it had everything I was looking for. With the addition of Crusher wheels and a flat load floor retrofit, it is damn near perfect. I would like to add the Auto-dim mirror with homelink and the power folding mirrors.
They attempted to add the Auto-dim mirror but got nothing when they plugged it in. Will the instructions in this post work for a 2016 Countryman? Thank you for the help!
Nathan
Nathan
#140
It should, that older MINI info but unless they mixed up the pinouts or had a factory wiring production change that would explain it. I would get the wires kit a couple pages back and test the wires with a voltmeter to see what signal is what wire, then follow the instructions a couple pages back. they might juts have the wires mixed up.
#142
#143
#144
so, follow the pdf instructions and auto dimming will work like factory save for not doing it in reverse?
not a huge deal, but will the dealer do that?
#145
Should be the same, but the GP2 was a special MINI with some odd changes. I would at least look at the pinout on the plug to see if it matches whats in the pics here for the DIY.
#146
Post above #137 then post#107 in that linked thread gives you the install PDF.
#147
#148
Read the thread that is specific to R60 coding. There is a ton of information in there and some instructions on how to do it. You may also put out a call to see if there is anyone in your region that is comfortable with the software, has the experience and the tools. I believe there are some newer wireless options as well. Do a search for the Carly app.
#150
ECS has what you need. You will have to splice some wire in to make it the correct length. I ordered 4 female ends, soldered some 18 gauge in to make the length work and following the wiring instructions. Including taking the trim off, it was less than an hour. I didn't even need any calibration.
